It is currently Fri May 25, 2012 9:46 pm
PostPosted: Sun Oct 30, 2011 7:18 pm
Been thanked: 1 times
Can anyone help , i switched on our shower only to discover it is not heating the water as per normal ,
it was used a few hours earlier with no problems .
Having a look at the instructions , there is a thermal cut-out on top of the can and element unit ,
seem to have voltage at the input side but no voltage at the out-put , does n't seem to be any
physical reset , is it shot ? does the whole assembly need replacing ? :dunno: any info will gladly be received
PostPosted: Sun Oct 30, 2011 8:52 pm
Has thanked: 57 times
Been thanked: 99 times
You can order a new high limit thermostat but this has been operated as unit over heated therefore there could well be another fault with it
How old is unit,did you get a scaling sound when run,is shower head scaled,hose damaged ,did the flow through the unit seem reduced?
If you have found help on the UHM's forums,why not help out the UHM's Nominated Charity,find out more here
PostPosted: Mon Oct 31, 2011 10:32 am
The showers approx 2 years old , can't see no scaling , the flow seems to be normal and i could n't hear anything abnormal ,
will give customer sevice a buzz to hear what they have to say , cheers for the reply
PostPosted: Mon Oct 31, 2011 10:44 am
Has thanked: 25 times
Been thanked: 71 times
Agreeing with WPM but only hazarding a guess, if there is no manual reset, would it reset by removing the power?
Users browsing this forum: OnlyMe and 15 guests
