It is currently Mon Jul 23, 2018 2:41 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Sat Sep 09, 2017 3:36 pm
Has thanked: 26 times
Been thanked: 29 times
It's very high humidity in a tub house/shed. Not realizing the implications, I at first put down carpet tiles that had a rubber backing. The floor is concrete. The result was green mould growing really well on the carpet tiles.
I solved the problem by chucking away the carpet tiles and putting down EVA foam mats. They are comfortable to walk on, water on the floor can evaporate and mould doesn't grow on them. They interlock, can be trimmed to fit odd corners and easy to lay, no adhesive required. Definitely a perfect solution, and cheap.
Laird
If all else fails, use 6 inch nails
PostPosted: Sat Sep 09, 2017 5:05 pm
Has thanked: 13 times
Been thanked: 8 times
That looks good, thanks.
is it the same as these..
http://www.ebay.co.uk/itm/Leisure-Black-Padded-Eva-Foam-Floor-Mat-Tiles-for-Awnings-Tents-Gyms-amp-Marquees-/262287247203?
DIY - Joining things together to make stuff ;)
https://ddmetalproducts.co.uk
PostPosted: Sat Sep 09, 2017 10:10 pm
Exactly these.
I think I got them quite a bit cheaper.
Laird
PostPosted: Sat Sep 09, 2017 10:45 pm
Has thanked: 673 times
Been thanked: 1934 times
i wouldnt over think it really :lol:
wood will only rot at around a constant 19% moisture
soaking wet ok
wet ok
dry ok
constantly fluctuating ok
constant 19% for months on end can be a problem
i would suggest just go for it and and suspect the worst will be the need to replace between 1 and 3 planks every few years :dunno:
PostPosted: Sun Sep 10, 2017 7:58 am
Thanks big-all, I never knew that, very odd :)
Thats one thing i'm not looking forward to - my one mistake (i think) was to build the walls on top of the floor, I should have designed/built the floor frame so the floor can be fitted/removed after the walls went up i think. This would have made floor repair a doddle instead of a tricky job. It can still be done of course but harder.
OTOH, we have decking step thats been outside for about 8 years now - no treatment at all and its still ok, looks rough but still structural, I guess if this lasts 8 years we will be ok i think :huray:
PostPosted: Sun Sep 10, 2017 2:58 pm
Just to give you an idea of what it looks like..
Laird
PostPosted: Sun Sep 10, 2017 3:12 pm
Nice :)
