It is currently Thu Dec 13, 2018 5:05 am
PostPosted: Thu Mar 08, 2018 6:15 pm
Has thanked: 4 times
Have a new touch switch I'd like to replace with the old in the kitchen.
As far as I know the touch switch is 10amp but the kitchen I assume is 13amp.
Will my new touch switch be able to cope with this? The load will not be more than 40-50watt.
I'm new to touch switches and it doesn't take earth or neutral so will need to cap them off.
PostPosted: Thu Mar 08, 2018 6:18 pm
Has thanked: 56 times
Been thanked: 589 times
you can not use that touch switch !! what you have is a switched fused spur you need to replace it for another
edit. that black spur looks to be hand painted
As for the wiring the 2 grey cables from the top of the back box are your ring main and the one on the left is the 'Load' (in your case the lighting)
For this message the author Bob225 has received gratitude : rook
PostPosted: Thu Mar 08, 2018 6:34 pm
Has thanked: 1507 times
Been thanked: 3810 times
Lighting circuits are normally on a 6 amp breaker/circuit. Strange that you have a sfcu there ? maybe a bodge from a previous diyer.
In theory (assuming I'm correct) connecting all the neutrals into a block then the live/switched live/s to (permanent live / com) switched to L1 and L2 respectively should work.
Before doing anything switch the light circuit off at the consumer unit, if the kitchen lights still work then get a pro in.
EDIT Oooooppppssssss... :welcomeuhm:
For this message the author wine~o has received gratitude : rook
PostPosted: Thu Mar 08, 2018 7:13 pm
its not uncommon to put undercounter lights on a fused spur :wink: its fused for a reason
PostPosted: Thu Mar 08, 2018 7:15 pm
Good spot. I'd assumed normal light circuit.
PostPosted: Thu Mar 08, 2018 9:17 pm
Thanks all.
I'll try and wire it up and let you know what happens.
Not sure what 'sfcu' is but it was all wired by a certified pro about 8-9yrs ago when we had the whole kitchen replaced.
PostPosted: Thu Mar 08, 2018 10:03 pm
Has thanked: 45 times
Been thanked: 1377 times
:stop: Don't!
Your lighting is fed from the ring main, you "switch" is a fused connection unit. It "drops" the amount of current available. (So far no problem)
If you add your new switch there will be nothing to "Drop" the current, so when a fault develops your switch will explode because there is too much current going through it. (Because you took away the fuse)
You can use that switch AFTER the sfcu, but not instead of the sfcu
For this message the author someone-else has received gratitude : rook
