It is currently Sun May 19, 2019 11:55 pm
PostPosted: Mon Apr 01, 2019 8:40 pm
Has thanked: 25 times
Been thanked: 116 times
I'm in need of a digital spirit level for general DIY use. Probably 60cm
I don't get on too well with standard bubble levels, I've had the GemRed one from Axminster for about 7 years now.
Not seen a lot of use, and not been dropped AFAIK not got wet, but it has starting behaving "strangely" sometimes will get stuck on one angle, sometimes will require calibration again and again.
I'm assuming there are no "user servicable parts" :)
I'd like something half decent but not too expensive.
I could just get another GemRed for £32 from axminster.
Seems to be a different model to the one I have
Actually this looks like mine
https://www.axminster.co.uk/gemred-digi ... vel-211592
I paid £40
The Stanley Fatmax is coming in at £75
Any opinions or other options please?
I am not a pro.
PostPosted: Mon Apr 01, 2019 9:12 pm
Has thanked: 59 times
Been thanked: 300 times
There is one here at rutland
https://www.rutlands.co.uk/sp+hand-tool ... nds+dk7500
PostPosted: Tue Apr 02, 2019 11:34 am
Old School Chippie
Has thanked: 808 times
Been thanked: 1616 times
The Bosch and BMI are both good digital levels - but cost significantly more. TBH I tend to use a combination of laser levels and decent spirit levels (in my case Stabila)
PostPosted: Tue Apr 02, 2019 12:01 pm
Has thanked: 34 times
Been thanked: 8 times
do you have a smart phone - could try the app
i have used on a normal level before , but just general DIYer
PostPosted: Wed Apr 03, 2019 11:37 pm
Old School Chippie
The problem with using something as short as a phone for many tasks should be self-evident - lack of base length. The longer a spirit level is the more accurate it is simply because it can take-out discrepancies in the length of a piece of material. Trying to use a smart phone on something like a door casing to check it for plumb and you'll probably fail. It just won't work if the legs are anything but dead straight (and let's face it what woodwork is ever dead straight?). A joiner's 6ft level works because it allows you to see any bow in the timber, and to correct it. So, basically while a smart phone app will allow you to check if your 150mm/6in wide framed photograph of Great Aunt Hermione is level, it'll be somewhat less useful if you are trying to level-up a 10ft run of book shelves........
PostPosted: Thu Apr 04, 2019 11:00 am
Has thanked: 42 times
Been thanked: 587 times
ive got laser levels and stabila levels. laser for setting out kitchens etc. stabila girder levels are great. sure theyre the 83s series...
https://www.its.co.uk/search.aspx?rs=st ... =match_and
never tried a digital level and i should imagine i can get what i need done with a combination of my laser level and my stabilla levels.
i do need to buy a new 6ft level though. my current one is 6'6" but its been knocked and am sure theres a slight bend in it last time i used it
PostPosted: Fri Apr 05, 2019 11:32 am
sorry, I should have explained a little clearer than I did - I used it on a level itself , which i may not have explained well in my statement fully
,as i know you need a longer surface and was useful where one of the long 4' level I had , i put the smartphone ontop of that level to see the bubble as i did not have one of these cleaver bubble levels, which i do have now and 6' lenght
PostPosted: Fri Apr 05, 2019 7:27 pm
Old School Chippie
Think about this: firstly the casing of a smart phone is nowhere near as perfectly machined as the surfaces of my Stabila levels and secondly a 1mm packer (or piece of grit) beneath the end of a 6ft level will cause a minor, but discernable, difference in the accuracy of the level - the same packer or dirt under the end of a 150mm long smart phone will cause an error 12 times as great. That would be totally unacceptable in, say, a door casing. So smart phone level software is only a vague indication of anything and cannot be trusted
PostPosted: Fri Apr 12, 2019 9:58 am
Thanks for the suggestions.
While deciding which one to go for, I've continued using my digital level as a normal level as it has the clearest bubble from my random selection of old levels.
Also, it is visible from above, which was very useful leveling something at ground level.
I came across this site, which seems to have a selection of cheaper digital levels.
https://www.machine-dro.co.uk/catalogse ... ital+level
They seem to have a good selection around the £20-£40 mark, which is more my kind of price range.
But for now mine seems to be working ok again.
Will sometimes jump out by 20° if I knock it too hard, but it has been better than it was, maybe it got damp or something.
I am not a pro.
