It is currently Mon Apr 22, 2019 3:19 am
PostPosted: Tue Mar 26, 2019 7:23 am
I have a Mira Vie electric shower and it has come loose at the top (gap between shower back and wall).
I turned the electricity off and opened it up and I took a photo so you can see what I mean.
Can anyone suggest a solution so that I can screw it back to the wall?
At the moment I am relying on a single screw at the bottom of the unit to hold it to the wall (which seems pretty sturdy for now).
I am hoping there is a cheap solution as I don't really have the money to spare for buying a new unit and having someone fit it for me....
Thank you!
File comment: Problem area highlighted in yellow square
PostPosted: Tue Mar 26, 2019 7:48 am
Has thanked: 415 times
Been thanked: 1549 times
Use a suitable washer on the screw.
PostPosted: Tue Mar 26, 2019 10:51 am
Has thanked: 33 times
Been thanked: 50 times
A washer or metal plate shaped - I'd probably but a blob of silicone over the repaired area to try to keep water out too seeing as there's
a hole in the case now
[I'm taking it as read that common sense is used regarding not having metal touch any conductors or come perilously close to doing so]
PostPosted: Tue Mar 26, 2019 9:20 pm
Has thanked: 82 times
Been thanked: 192 times
I do appreciate what others have said,but OP probably doesn'thave the facilities to make a shaped plate, or file down a washer to make it the right shape.
I would drill a new hole in the casing, to the side of the mounting shown, and make a new fixing.
OP, what is the wall made of? Is it showerwall laminate or tiles over masonry?
