It is currently Mon Apr 22, 2019 1:26 am
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
PostPosted: Tue Mar 19, 2019 8:26 am
Has thanked: 206 times
Been thanked: 27 times
So at the moment this double socket (which I'm pretty sure is really a single with an adapter faceplate) is sitting too low and I want to move it higher and in maybe a slightly different location. Potentially the wires may need extending to do this. Is it just a case of using crimps then insulated tape to join? Image
Sent from my SM-G950F using Tapatalk
PostPosted: Tue Mar 19, 2019 8:47 am
Has thanked: 82 times
Been thanked: 192 times
If you isolate the circuit and remove the single adaptor faceplate (which it is) you will be able to ascertain if the ring main cables come up from the floor (a) or down from the ceiling (b). If in doubt give us a picture of the back box exposed.
(a) chase out up the wall to a new double back box let in to the wall; make the junction/extension with wagos inside the single back box and fit a single blank plate over it.
(b) very carefully chase out around the existing cable by hand up to the point that you want the new back box, you will have enough cable without extending anything.
For this message the author arco_iris has received gratitude : kevinsmbuk
PostPosted: Tue Mar 19, 2019 9:26 am
Has thanked: 923 times
Been thanked: 405 times
Wago's are great but personally I'd crimp and heatshrink and cover the single socket with plaster. No point having a blank plate in the wall if there's no need. Particularly if you wish to have higher skirting boards and the blank plate would obstruct that which happened in my case.
I understand wago's would be the quicker option but there's mixed messages whether they are maintenance free (MF) or not so you can't bury them.
I'm not an electrician so maybe an electrician would confirm if wago's are MF or not.
For this message the author Argyll has received gratitude : kevinsmbuk
PostPosted: Tue Mar 19, 2019 9:29 am
Ok thanks chaps. So hopefully cables go up (which I'm pretty sure they do) then I will just relocate the box higher rather than moving it. Will fill the old backbox after with bonding/multi.
PostPosted: Thu Mar 21, 2019 12:28 pm
Just to clarify, if wires needed to be extended and plastered over in the wall. Then would crimp connectors and insulation tape be legal?
PostPosted: Thu Mar 21, 2019 3:45 pm
Has thanked: 33 times
Been thanked: 50 times
There's much debate over using crimp connectors on solid core cable, consensus is it shouldn't be done,
I have and nothing bad has happened yet....
Some Wago are maintenance free so it says on their site http://www.wago.ltd.uk/enclosures/wagobox/
If I was to use these I'd go for the genuine Wago over generic as I read somewhere about the ones from CEF
failing throwing in to doubt their MF credentials.
Screw type 'chocolate bloc' aren't MF though, if used, access for inspection is required.
For this message the author jaeger has received gratitude : kevinsmbuk
PostPosted: Thu Mar 21, 2019 3:50 pm
Maybe not on this site because this is where I was told to use it from a few members.
PostPosted: Thu Mar 21, 2019 4:09 pm
Just google 'using crimp connectors on solid core cable'
Will tell you more than I can type here.
PostPosted: Thu Mar 21, 2019 4:16 pm
Thankfully nothing needed extending, but it's interesting to know that information thankyou. The wiring in this house is actually stranded core (it's a 60's house with green goo type outer sheathing!)
New backbox, gromits fitted, flying earth now fitted too. Just got waiting for bonding to go off then will fill the rest, sand and screw faceplate on properly
PostPosted: Thu Mar 21, 2019 4:17 pm
PicImage
PostPosted: Thu Mar 21, 2019 6:19 pm
Has thanked: 41 times
Been thanked: 1470 times
If you have green goo, that is the cable starting to breakdown :shock:
PostPosted: Thu Mar 21, 2019 6:43 pm
Has thanked: 1550 times
Been thanked: 3892 times
Certainly worth getting an EICR done.
PostPosted: Thu Mar 21, 2019 6:58 pm
I thought it depends on the grade/quality of the cable? As I understand it with this type of cable it is the plastercizer in the cable breaking down under relatively low load.
When the kitchen is done we are putting a separate ring circuit in which should reduce load on the rest of the ring anyway.
PostPosted: Thu Mar 21, 2019 10:03 pm
Yes it does depend on the cable, but if it has green goo (and yours does) it is breaking down, there is no cure, it needs to be changed. it is not going to get any better.
The idea of a cable sheath is not only to give it some mechanical protection but to be an insulator too. As the insulation breaks down arcing can occur causing fire.
Don't panic, it's not going to happen in the next ten minutes, but if you ignore it, chances are it will happen.
For this message the author someone-else has received gratitude : kevinsmbuk
PostPosted: Fri Mar 22, 2019 2:12 pm
Thanks for the information. So the long as short of it I am looking at a full rewire at some point!
