It is currently Mon May 20, 2019 12:03 am
 Post subject: Rising Damp
PostPosted: Sat Mar 16, 2019 11:03 am
Has thanked: 7 times
1920s property with Bitchuman DPC between bricks I think, never found a visible layer between bricks but DPC present under joists. Cause is outside bridging of the DPC which will be lowered to 150mm below joists.
Plaster removed to damp areas.
Moister readings are in 20s in these areas after being open to the air for 2 months.
When is it safe to replaster? I will use waterproof agent in cement render or a Tanking product to waterproof.
Any thoughts please?
John
 Post subject: Re: Rising Damp
PostPosted: Sat Mar 16, 2019 5:41 pm
Has thanked: 35 times
Been thanked: 25 times
Hi
If it is a single brick wall, maybe you need to use lime render (externally) and lime plaster (internally) and not cement...
Sent from my Nexus 5X using Tapatalk
PostPosted: Sun Mar 17, 2019 9:55 am
[quote="sammy.se"]Hi
Thanks. Was more interested in when it will be safe to plaster over the walls. What harm am I doing in plastering a wall that is damp if I am taking precautions to prevent further dampness at same time.
Double brick wall
PostPosted: Mon Mar 18, 2019 4:15 pm
Yes, I get your point. The reason i bought up lime, was because lime will 'breathe', and so even if the wall was slightly damp, it will eventually dry out. The same is not true for cement - any moisture still in the wall will remain trapped. Is the external wall rendered or exposed bricks? If it's brick, then moisture can still escape that way, if you plastered the inside. If it's rendered i would consider waiting to you are sure the wall is fully dry.
Cheers,
S
