It is currently Mon Apr 22, 2019 3:19 am
PostPosted: Fri Mar 15, 2019 8:24 pm
Has thanked: 3 times
Hi there
I’ve just bought new induction hob but unlike oven there are 2 cables that come out the back,one large one,one smaller one.im a bit miffed on connecting these up.any help would be appreciated. :dunno:
PostPosted: Fri Mar 15, 2019 8:56 pm
Has thanked: 41 times
Been thanked: 1470 times
Seeing as you have the hob and we don't, what do the instructions say?
For this message the author someone-else has received gratitude : Wayne3331
PostPosted: Fri Mar 15, 2019 10:08 pm
How do you post picture I’m on iPad trying to find pic mod ?
PostPosted: Fri Mar 15, 2019 11:31 pm
I hope this comes through
PostPosted: Fri Mar 15, 2019 11:34 pm
Here are the cables
PostPosted: Sat Mar 16, 2019 12:15 am
You connect it as per the drawing you have.
The drawing you choose depends on what supply you have (As the drawing shows) you either have a 50A mcb or a 32A mcb and a 16A mcb (again, as per drawing)
PostPosted: Sat Mar 16, 2019 7:10 am
So if I’m using drawing on left I have to connect all the lives together then all the neutrals and then earths ect.can you do this in like a junction box and then from that down to dp switch then to 50amp breaker.
PostPosted: Sat Mar 16, 2019 2:55 pm
Has thanked: 65 times
Been thanked: 560 times
Standard way would be a cooker connection unit, you can get double cooker connection units that will take the two cables. Clearly a commercial induction hob to need so much power.
PostPosted: Tue Mar 19, 2019 2:51 pm
Has thanked: 1550 times
Been thanked: 3892 times
how you wire it depends entirely on your existing wiring. Pic of the CU and the cooker switch please. (domestic switches are normally rated @ 45 A max)
You can't just replace say a 32 Amp breaker for a 50 Amp breaker without upgrading the supply cable.
For this message the author wine~o has received gratitude : Wayne3331
PostPosted: Tue Mar 19, 2019 6:39 pm
The cable that was there was a 6mm with 40 amp mcb. I have changed this for a new 10mm one with a 50 amp breaker.
Cu is Hager.
Have not purchased a cooker outlet yet as I did not know if there would be anough room to connect the cables in a standard one.
So to recap 50amp mcb to 45amp dp switch to cooker outlet to hob.
The cable length is 5m long and is running in an 18 inch void under the floor if this helps(diversity)
PostPosted: Tue Mar 19, 2019 7:12 pm
Diversity might help, but I'd be looking at a 50 Amp cooker switch to be on the safe side. They are fugly though..
https://www.screwfix.com/p/crabtree-2-g ... hite/99780
You'll also need the correct backbox
PostPosted: Tue Mar 19, 2019 8:40 pm
Yes they are lol.
Cheers for the quick reply.
So I know I’m repeating myself so I just need to connect l1 and l2 of larger cable to l1 of the thinner cable and n1 and n2 of larger cable to n1 of thinner cable. And then earths etc into cooker outlet in respective connectors and then 10mm from that to the 50 amp dp switch and then on to cu .
PostPosted: Fri Mar 22, 2019 8:54 pm
Approved Electrician
Has thanked: 175 times
Been thanked: 594 times
Beauty is in the eye of the beholder.
https://www.screwfix.com/p/schneider-el ... hite/1658j
My slim line model does not give me a neon evil eye.
