It is currently Sun Apr 21, 2019 3:44 pm
PostPosted: Thu Mar 07, 2019 5:15 pm
Has thanked: 3 times
There are some stud partition walls in our house and all of them suffer from the same problem. The plaster covering many of the nails that attach the plasterboard to the studs does not stay in place for long. After about 18 months, a circular crack of about 25mm in diameter always appears around these nails.
Is there some semi-flexible filler that can be sanded to a smooth finish that might do a better job than Polyfilla for covering these nails?
PostPosted: Thu Mar 07, 2019 5:34 pm
Has thanked: 415 times
Been thanked: 1549 times
Punch the nails home just a little bit first before you fill. What you're seeing is a sure sign that the nails are very slightly loose. Any filler will fail if it's left as it is and any filler should work after you've given them a tap home.
PostPosted: Thu Mar 07, 2019 5:51 pm
I've already tried that without any success, but I've just bought myself a heavier hammer, so perhaps that might do the trick!
PostPosted: Thu Mar 07, 2019 6:05 pm
Has thanked: 1550 times
Been thanked: 3892 times
Get rid of the nails, use screws. fill once and forget.
PostPosted: Thu Mar 07, 2019 9:21 pm
Thanks for that interesting suggestion, which I'd never thought of trying before. I'll give it a go.
PostPosted: Thu Mar 07, 2019 9:26 pm
On reflection, it might prove difficult to remove the nails without seriously damaging the plasterboard, but I guess the solution to that would be to place the screws in slightly different locations. If the screws stop the plasterboard from moving, then the plaster over the old nails should hopefully now stay in place.
PostPosted: Sun Mar 10, 2019 8:44 am
aye . good point...
Use proper plasterboard screws.
