It is currently Sun Apr 21, 2019 10:01 pm
 Post subject: Lidl 17th March diy out
PostPosted: Thu Mar 07, 2019 4:39 pm
Has thanked: 59 times
Been thanked: 300 times
Planer, angle grinder, bandsaw, detail sander, cordless screwdriver multi head, gas soldering iron. various consumables
https://www.lidl.co.uk/en/MiddleofLidl.htm?id=997
PostPosted: Thu Mar 07, 2019 5:34 pm
Has thanked: 656 times
Been thanked: 1861 times
The Bandsaw might be good for a DIY woodworker.
Painting with BIN
PostPosted: Fri Mar 08, 2019 5:25 pm
I've got the angle grinder but not used it much yet seems ok.
Already got a rothenberger gas soldering iron otherwise I would get the soldering iron, using it to make a planting mats for allotment it seals the plastic as it cuts to stop fraying which is bad on the cheaper weed control fabric. Quite useful things to have around, for moulding bits of plastic, heat shrinking, paint removal, bits of sign pyrography, heating up awkward nuts etc. uses standard butane lighter gas
PostPosted: Fri Mar 08, 2019 6:00 pm
Has thanked: 33 times
Been thanked: 50 times
Age restricted content warning?
Angle grinder doesn't seem bad for the money.
PostPosted: Fri Mar 08, 2019 6:09 pm
Has thanked: 45 times
Been thanked: 750 times
I have the variable speed angle grinder, it's awesome!
I fitted a chuck to it so I can use it as a right angle drill for tight spaces.
PostPosted: Fri Mar 08, 2019 6:49 pm
Has thanked: 141 times
Been thanked: 174 times
I’m curious now, how did you manage to do that?
Mike
PostPosted: Fri Mar 08, 2019 7:49 pm
Mike
I bored out and re-tapped a drill chuck to M14.
PostPosted: Fri Mar 08, 2019 8:37 pm
Mike
Ahh!, now I understand!!
Well done, great idea :thumbleft:
Mike
PostPosted: Fri Mar 08, 2019 9:05 pm
Thanks. You can buy M10 chucks which fit the mini angle grinders, unfortunately they don't do M14 chucks for this purpose so I made my own.
PostPosted: Fri Mar 15, 2019 11:14 pm
Has thanked: 28 times
Mike
Any chance you can tell me where you got the drill chuck. I have been looking to do the same thing but the only chucks I can find have 13mm female thread and I doubt there will be enough metal left to tap to 14mm.
Cheers.
Col
PostPosted: Sat Mar 16, 2019 6:49 am
Mike
Cheers.
Col
The minor diameter for an M14 thread is 12mm. 1/2-20 thread has a major diameter of 12.54mm. By the time I bored out the threads it was closer to 13mm but that was still plenty for me. If the threads ever strip I will just make another.
You could be a 3/8-24 or an M10 chuck if you were worried, I wasn't.
