It is currently Thu May 23, 2019 2:47 pm
PostPosted: Mon Mar 04, 2019 9:49 am
Has thanked: 5 times
Been thanked: 15 times
Hi, some advice would be brilliant.
I'm panelling a nook for a client with 9mm butt and bead cladding made from green MDF.
They want a shelf recess turning into a cupboard with the same material.
The question is how to thicken this stuff to make it thicker and more able to take hinge screws?
I tried laminating with 5mm ply over the weekend but it has banana'd by an inch (different materials/expansion? Under floor heating?)
Do I just need a better flat surface than the (unbeknown to me, heated) floor?
Should I think of framing the back with 15mm battens instead?
Dunno, what's the best approach?
Many thanks.
PostPosted: Mon Mar 04, 2019 9:58 am
Has thanked: 659 times
Been thanked: 1875 times
Glue same to same. Another piece of 9mm glued on makes up and 18mm thickness which is ideal. Use a non water glue to avoid any bending. If you have a router you could make your own panels up using a thicker board. The cutter is the biggest expense though.
Painting with BIN
PostPosted: Mon Mar 04, 2019 10:09 am
Has thanked: 710 times
Been thanked: 2043 times
cut and store in the same room for several days to acclimatize to reduce the expansion risk to a minimum
it may be easier to remake in 12mm mdf
PostPosted: Mon Mar 04, 2019 10:24 am
Hmmm, thought you might say that. Guess I'm off to buy more panels then...
Thanks.
