It is currently Sun Apr 21, 2019 3:24 pm
PostPosted: Sun Mar 03, 2019 6:57 pm
Has thanked: 3 times
Been thanked: 2 times
Hi.
Any tips? I've got all the units cleaned up and will replace the handles but there are bits in the corners where I guess they glued net curtains or something.
I just can't shift it.
I can't get a low enough resolution pic to attach bit it just looks like yellow old glue thatso hard.
Cheers!
PostPosted: Sun Mar 03, 2019 7:07 pm
Has thanked: 4 times
Been thanked: 1 times
Have you tried solvent thinners?
PostPosted: Sun Mar 03, 2019 7:36 pm
White spirit? Ooh not yet but will have a go thanks. I was just using elbow grease and thinking about getting a hair dryer on it!
Has thanked: 81 times
Been thanked: 192 times
Don't rely on my answer but,
If all else fails you can very carefully, with a flat block, use 240 grit emery paper & a bit of water, sand off most the glue, then change to 500 or 600 grit, still with water (wet'n'dry)*.
Then polish with "T-Cut" that comes from motor accessory shops.
If still a bit dull * go to 1000 or 2000 grit "flour paper" then polish..... it'll end up looking like a Rolls Royce. Good Luck.
My decorator damaged a upvc window sill by accident, he used this process, perfect finish. Saved him paying for a new sill.
PostPosted: Mon Mar 04, 2019 3:33 pm
Cheers!
