It is currently Sun Apr 21, 2019 7:26 am
 Post subject: HOW I EARTH?
PostPosted: Tue Feb 19, 2019 8:39 pm
Has thanked: 1 times
Can any electricians advise how I may construct a DIY interior earthling kit after applying emf shielding paint to an interior wall? Thanks.{UK}
 Post subject: Re: HOW I EARTH?
PostPosted: Tue Feb 19, 2019 9:09 pm
Has thanked: 33 times
Been thanked: 50 times
Taken from the web:https://emfields-solutions.com/shielding/paint.asp
Earthing/Grounding instructions (only if you have determined it needs doing)
Measure a length of wire needed to connect the painted surface to the nearest radiator or socket, plus some spare to allow it to be made secure, avoiding the danger of tripping people up or being torn from the painted surface.
Take the plastic coating off both ends of the wire.
Tape one end of the wire to the painted surface. You may want to splay the wires to get maximum contact.
Attach the other end of the wire:
To a metal part of an earth bonded radiator.
You may need to scratch away the paint off a small area to ensure wire-to-metal contact. Tape in place.
Some plumbers use plastic pipes in the radiator system. These systems will not be connected to the house earth. (You should use the second method of attaching the wire)
To the earth pin of a standard plug. Plug it into a socket and the painted area will be connected to the house earth, whether the switch is "on" or "off".
PostPosted: Tue Feb 19, 2019 9:50 pm
Has thanked: 41 times
Been thanked: 1469 times
I have to ask, why?
PostPosted: Wed Feb 20, 2019 6:23 am
Has thanked: 234 times
Been thanked: 192 times
Thoughts of Chuck McGill in better call saul spring to mind.
PostPosted: Wed Feb 20, 2019 10:48 am
Has thanked: 65 times
Been thanked: 560 times
A Faraday cage does not need earthing, as to taking it to an existing earth point it depends why you want it earthed? Being earthed is not the same as being bonded, in a house we bond metallic items together so they are all the same polarity. This may not be the same as the earth outside. With a TN electric supply under fault conditions bonding voltage can be very different to earth, even earth outside can have a gradient of voltage so one has to be careful with metal buildings often the reinforcing bars in the concrete base are bonded to metal structure.
On a gas plant where I worked, there was a huge resistor connecting supply earth to site earth to limit current flow, sticking in one earth rod likely 30 odd ohms is not a problem, putting in an earth mat with rods at each corner likely 0.03 ohms however can be a problem.
I know operating theatres often have special floors to stop sparks, but again these are bonded not earthed, radio hams however want a true earth, so what are you trying to do.
PostPosted: Wed Feb 20, 2019 5:13 pm
Been thanked: 676 times
What are you trying to do ?
PostPosted: Sun Feb 24, 2019 8:14 pm
More detail:Shielding my lounge wall against neighbours so called `smart meter` {CANCER BOX} RF Pollution .
PostPosted: Sun Feb 24, 2019 8:28 pm
oh, You do realise that to stop the "RF Pollution" you will have to (since you used paint) paint all the walls and the floor and the ceiling, otherwise you really are wasting your time and paint (oh and money) since RF signals radiate outwards, and not just from smart meters. There are numerous other devices too.
For this message the author someone-else has received gratitude : brokentechie
PostPosted: Mon Feb 25, 2019 6:14 am
Has thanked: 45 times
Been thanked: 750 times
Don't waste your time and money, there is an easier solution. Get yourself down to Tesco and next to the cling film and sandwich bags you will find tin foil. Make sure it's tin foil, not aluminium, that gives yous dementia.
Take the tin foil, wrap it round your head and then start shouting inane crap about GMO's and Monsanto into your megaphone.
If you feel any side effects get some homeopathic cyanide to sort it out.
PostPosted: Mon Feb 25, 2019 5:13 pm
Has thanked: 1550 times
Been thanked: 3892 times
Half of those smart meters don't work anyway.
Far less dangerous than crossing the road.
PostPosted: Mon Feb 25, 2019 5:23 pm
Smart meters are only very low powered devices as they run off batteries the gsm is only active when paged
you have more chance of getting hit by a bus driven by Elvis Presley than getting cancer from a smart meter,
For this message the author Bob225 has received gratitude : wine~o
PostPosted: Mon Feb 25, 2019 6:32 pm
https://smartmeterguard.com/
$130 ::b
PostPosted: Mon Feb 25, 2019 6:35 pm
Bob225 wrote:
you have more chance of getting hit by a triple decker purple bus driven by Elvis Presley wearing an I love Kylie T-shirt than getting cancer from a smart meter,
My edit. :hiding:
PostPosted: Tue Feb 26, 2019 7:59 pm
Approved Electrician
Has thanked: 175 times
Been thanked: 594 times
wine~o wrote:
My edit. :hiding:
And the odds of finding 3 wise men and a virgin in Essex?
For this message the author OnlyMe has received thanks - 2: Bob225, OchAye
PostPosted: Wed Feb 27, 2019 11:41 am
You may in a convent but don't make a force of habit of it
cron
