It is currently Sat May 25, 2019 8:57 am
PostPosted: Sat Feb 16, 2019 5:25 pm
Has thanked: 41 times
Been thanked: 1480 times
I am wanting to add some Fernox F1 protector (Combi boiler) It says I can add it via the fill loop, but mine only "seems" to have one tap to turn off (not a problem, he said hopefully) so I was wondering is this the next best way (see following)
1) Turn off boiler
2) Put small bucket under drain off valve under the floor.
3) Open drain off valve, fill small bucket
4) Open / remove upstairs radiator bleed valve screw
5) Close drain off valve
6) Inset pipe into radiator and fill with F1
7) When F1 bottle empty, put bleed screw back
8) refill / pressurise
9) Turn boiler back on
I also purchased a filling kit with the F1, but its not quite suitable, so I adapted it......
File comment: Yes, I know its blocked with silicone, but I am waiting for it to cure first, then I am going to trim the "pipe"
If there is an even easier way, please say so.
PostPosted: Sat Feb 16, 2019 5:47 pm
Has thanked: 327 times
Been thanked: 975 times
Sounds about right. If you have one a towel rail is the best one to use as you can just remove the 1/2" bleed from the top and bung it straight in
For this message the author Razor has received gratitude : someone-else
PostPosted: Sat Feb 16, 2019 6:07 pm
Thankyou. :thumbright:
Sadly, no towel rail.
PostPosted: Sun Feb 17, 2019 11:29 am
Thanks again, it worked very well. (Almost) almost done and the tube popped out of the bottle, the silicone had not set 100%, but 90% of the F1 had gone into the radiator.
