It is currently Sun May 19, 2019 3:48 pm
PostPosted: Thu Feb 14, 2019 1:06 pm
I'm planning what i need to do for my basement, and would like to soundproof a couple of walls, and the ceiling which goes to the living room above.
I found some Knauf soundsheild plus SE 12mm plaster board for £14 (2.4 x 1.2m)
Is this stuff any good? Or is it better to have 2 layers of normal plaster board? (works out the same price, but not sure of two normal boards would perform better)
the boards will have insulation behind them as i'll have battens off the wall, not to sure on the ceiling yet, if it's worth insulating between the joists?
I'm open to any other methods.
PostPosted: Thu Feb 14, 2019 8:19 pm
Old School Chippie
Has thanked: 808 times
Been thanked: 1615 times
Six of one - half a dozen of the other. Personally I'd go g]for a single layer of soundbloc these days - less work to install, less weight to carry on the joists, etc. Note that you need to make the very mimimum number of cuts in the boards and that all the joints need to be bang-on (no gaps). It is therefore advisable to check the joints for straightness and correct as necessary
For maximum effect use instead something like a Gyplyner metal framing system (often cheaper than timber framing) with a small airspace behind it (between it and the wall) and bed it onto an acoustic bedding material (tape/silicon). The performance of ceilings can be greatly improved by mounting the boards onto a resilient bar system rather than timber battening. The idea is always to remove the number of points at which sound vibration can be directly transferred between components of the building. Should you use between joist insulation, go for something like mineral wool batting and cut it so that it is slightly tight. This may require a tool such as the Stubai insulation knife, which will make a neater cut and generate a lot less dust although a mask, goggles and Marigolds are still very advisable
PostPosted: Thu Feb 14, 2019 10:38 pm
Has thanked: 235 times
Been thanked: 180 times
Or you go go acoustic insulation between joists then two plasterboard sheets with a acoustic mat (2mm) sandwiched between.
Amazon sell it....
Advanced Acoustics Soundproofing Mat 3m by 1.25m by 2mm thin https://www.amazon.co.uk/dp/B00BSBMFBM/ ... zCbPDY01R0
PostPosted: Sat Feb 16, 2019 3:17 pm
Thanks.
I'll have a look into these this evening.
Much appreciated
