It is currently Sun Apr 21, 2019 7:25 am
 Post subject: Temperature Assumptions?
PostPosted: Mon Feb 11, 2019 5:16 pm
Has thanked: 16 times
Been thanked: 13 times
Quick question about heat output from a radiator. I spotted on rated at 5569BTU. When manufacturers make their calculations, what temperature drop do the assume between feed and return water temperates, and what room temperature do they assume?
It always takes longer than I thought
PostPosted: Tue Feb 12, 2019 12:29 pm
Has thanked: 28 times
Been thanked: 143 times
Radiators should be tested to BS EN442, which specifies: Flow - 75C, Return - 65C, Room - 20C. This gives a Delta T of 50C
Some unscrupulous firms still quote the earlier standard which used a Delta T of 60C, thus giving "more" output.
For this message the author D Hailsham has received gratitude : AlwaysLearning
PostPosted: Tue Feb 12, 2019 4:51 pm
Has thanked: 840 times
Been thanked: 941 times
Depends what boiler you have.
If a condensing model, then the temp difference between flow and return is 20c, if non-condensing then it is 11c.
Dave
www.drlgas.co.uk
PostPosted: Tue Feb 12, 2019 7:58 pm
I wouldn't want to touch 70C for very long - that's well into contact burn injury territory
PostPosted: Tue Feb 12, 2019 8:04 pm
That got me hunting for my boiler spec - it has the flow/return differential as 12C for my, what I've always thought of as, condensing combi boiler. :dunno:
PostPosted: Wed Feb 13, 2019 9:33 am
Make and model of your boiler?
PostPosted: Fri Feb 15, 2019 12:32 am
Worcester Bosch 35CDi II
PostPosted: Sat Feb 16, 2019 11:24 am
If the GC number is 47 311 58, then it's not a condensing boiler; it's just a modulating (variable output) combi boiler.
The GC number is on the front cover of the Installation Manual, or on the boiler's data plate.
PostPosted: Sun Feb 17, 2019 12:39 am
Always nice to know what the white box is called!
