It is currently Fri May 24, 2019 8:13 pm
 Post subject: Water Resistant Paint?
PostPosted: Tue Feb 05, 2019 10:05 am
Has thanked: 34 times
Been thanked: 2 times
I'll try and keep this short. New house had painted tiles around the bath. They need to stay painted for the time being.
I put Zinsser BIN over the horrible colour that was on and coated with some mid-grey Valspar v500 I had left over from the kitchen. Problem. It bubbles and peels when the warm shower water lands on it.
Have now given it a quick rub and re-coated with BIN.
What do I need to put over it, oil based paint? Need a mid-grey satin finish....
Thanks.
PostPosted: Tue Feb 05, 2019 11:19 am
Has thanked: 796 times
Been thanked: 896 times
BIN does not like water. Emulsion (whatever valspar 500 is) on top of bin is a waste of time. Given paints are not meant to resist for long water, oil based undercoat and gloss would be your best bet . You may have to scrape a lot of paint BIN etc since you now know you do not have adhesion.
A different approach would be to look at some Multi Surface Paints (MSP) e.g. Bedec, check the spec if they are suitable for outside use and if yes chance it. One of the bedec things I had used stuck very well so there would be no need for BIN. Probably easier than going down the route of oil based paints.
If it helps a little.
For this message the author OchAye has received gratitude : DekHog
PostPosted: Tue Feb 05, 2019 11:27 am
That's a real help, thanks for your reply......
.....have just read again. All the existing paint has to come off?? Eeek!
PostPosted: Tue Feb 05, 2019 11:45 am
Slow down! You got a new house and it is not high on your priorities fitting a new bathroom I get that.
If the old paint was well stuck then you should have cleaned it A LOT. No soap residue left on it, no mildew etc. Scotchbrite pads would be ideal. You must rinse all chemicals off after you finish cleaning.
The paint you put on since then. If BIN has stuck well you might as well chance and paint over it but not with emulsion. If you did not prepare the old surface well then BIN may not stay up for long anyway leaving aside bin is not suitable for external use. If you can return the surface back to the old paint would be the best approach. Then chance Bedec MSP. It comes in satin and in some colours but as I found out when I used it and since then it was verified here, satin does not have good opacity.
PostPosted: Tue Feb 05, 2019 11:50 am
Thanks. The old surface was cleaned to death with pads and meths then washed down with warm water and hand dried. Am sure it was as clean and grease free as it could possibly be! I'll look for the paint you mention or try and find data sheets for it......
PostPosted: Tue Feb 05, 2019 10:01 pm
Has thanked: 248 times
Been thanked: 255 times
You can spot prime BIN on exterior but I think it's too brittle for anything else outside. I've used it on kitchen tiles with emulsion on top followed by a gloss varnish and it's been solid for 7 years.
PostPosted: Tue Feb 05, 2019 11:08 pm
Where have you been Desmondo15? You left me alone ::b :lol:
The thing with the problem above is, it is not clear to me which paint is coming off. The emulsion or the emulsion and BIN?
PostPosted: Wed Feb 06, 2019 8:49 am
Highly likely the Valspar bubbling. The BIN will do its job but needs to be under another system as it's job is adhesion not water proofing.
I think you could put anything on as long as it's finished with something that stops water coming through like a clear varnish, I'd have to research that a bit though.
Have a look at tile paint and see what there spec sheets say.
Sorry Ochaye but it's been so quiet here I hadn't felt the need to offer any advice mate.
For this message the author Desmondo15 has received gratitude : OchAye
PostPosted: Wed Feb 06, 2019 11:49 am
Has thanked: 1561 times
Been thanked: 3914 times
according to the zinsser book, Bulls eye 1-2-3 is the most suitable primer.
PostPosted: Wed Feb 06, 2019 5:56 pm
Looks like a good option.
I think the top coats are the biggest issue.
PostPosted: Thu Feb 21, 2019 5:01 pm
Well, left the BIN on as was almost sure this wasn't the issue..... had half an old tin of Ronseal white tile paint, so painted over the BIN with it using a 4" roller. The tin says use a brush, but I wasn't impressed with the finish it gave, and was also going to need two coats if brushed on.
A week of getting soaked with hot shower water and it was totally bullet proof, so went and bought a tin of the grey Ronseal which very effectively covered the white in one coat (roller again). No problems since, and seems like it'll last forever.
Thanks to all for the input.
For this message the author DekHog has received gratitude : OchAye
Users browsing this forum: Rayza and 0 guests
