It is currently Tue Apr 23, 2019 11:11 pm
PostPosted: Fri Feb 01, 2019 5:19 pm
Has thanked: 7 times
Been thanked: 1 times
Can anyone tell what this plastic strip is between my UPVC window and window sill ?
Is it required ?
Its looking a bit yellowed, could I remove it, foam the gap and fill and paint over ?
PostPosted: Fri Feb 01, 2019 5:36 pm
Has thanked: 926 times
Been thanked: 405 times
Do you mean the quadrant piece? if so you'd be best removing it and replacing it. It's a five minute job.
https://www.ebay.co.uk/itm/White-19mm-Window-Door-Plastic-uPVC-Skirting-Quadrant-Trim-Pack-of-10-/192625588526
For this message the author Argyll has received gratitude : piatti
PostPosted: Fri Feb 01, 2019 6:45 pm
Has thanked: 234 times
Been thanked: 192 times
They're fitted to fill gaps between window and cill, as above easy to replace, you could use flat bar if you don't like the quadrant.
For this message the author Ktuludays has received gratitude : piatti
PostPosted: Fri Feb 01, 2019 7:07 pm
Has thanked: 59 times
Been thanked: 300 times
As Argyll and Ktuludays says
you might be able to get a single length if thats all you need from your local builders/ DIY eg wickes do some I think its 3.29 per length, fix with silicone after removing the old and cleaning surface
As a guide they fix some in this video from about 4mins onwards
https://www.youtube.com/watch?v=XikWavpuBOU
For this message the author boxedin has received gratitude : piatti
PostPosted: Fri Feb 01, 2019 8:27 pm
Thanks, will try and remove tomorrow and see how wide the gap is
