It is currently Thu May 23, 2019 2:05 pm
PostPosted: Wed Jan 09, 2019 12:20 pm
Has thanked: 3 times
Been thanked: 2 times
Just a question.......
All my internal upstairs walls (1970's house) are paramount board, which I've only recently discovered about. To me these are very lightweight with minimal studding.
At the moment, all the doors are light moulded doors, but I really wanted to get some oak veneer doors which are going to be about 35kg+ each.
I am just wondering whether I have the appropriate walls or not, especially where two sets of two doors will be hanging right next to each other on opposing sides of the same stud wall separating the bedrooms (I realise that probably doesn't make much sense, sorry).
I realise I might be worrying about nothing, but everything has it's limit!
Ta.
PostPosted: Wed Jan 09, 2019 2:32 pm
Old School Chippie
Has thanked: 808 times
Been thanked: 1616 times
For anyone unaware Paramount is something like two layers of 9.5mm plasterboard with cardboard honeycomb in between and is about 57 to 60mm thick overall. For that reason they usually fit lightweight doors. Paramount partition tends to have a thin batten in between the plasterboard from floor to ceiling but often only something like 22m thick, and the door casings are fixed into that. It may be possible to get the door casings out then remove the batten and replace it with a piece of 2in (50mm) softwood either side of a door casing, glued in place and fixed at the bottom into the floor and at the top into the ceiling to provide strength for the heavier doors. A joiners shop or proper timber yard should be able to rip down some 2 x 2 or 3 x 2 PSE or CLS (cheaper) for you to the exact dimensions. BTW there is an undersize CLS sold by some merchants which finishes at 38mm thick and is a near exact fit inside Paramount panels
PostPosted: Sat Jan 12, 2019 3:25 pm
Thanks for that!
I assume that means you think that they won't be strong enough as is. I don't know if I can be arsed to retro-fit as suggested bit will mull it over!!
Thanks again mate.
PostPosted: Sat Jan 12, 2019 4:10 pm
Old School Chippie
Yes. The timbers in Paramount walls are generally very thin which is whey they fit ultra lightweight doors and frames. Put heavier doors on without beefing it up and the frames can move which will probably ground the doors (depending on weight)
PostPosted: Sat Jan 12, 2019 6:21 pm
As long as the walls wouldn't move !!!!!!
I think you've persuaded me for lightweight. Will be cheaper as well....
Wickes do some decent looking modern looking lightweight doors. Just have to convince SWMBO.....
Cheers.
