It is currently Tue Apr 23, 2019 1:18 am
 Post subject: Doorbell wires
PostPosted: Wed Nov 28, 2018 8:14 am
Hi all,
I'm after some help installing my Ring Pro Doorbell.
I'm at the section I need to bypass my doorbells transformer but I'm unsure of the wires to connect.
I have attached the photo of the wires 6 wires I have. The wires that lead to my doorbell are 1 yellow and 1 red to one terminal and 1 blue and 1 black to the other.
I'm not sure on the cable to attach to the bridging cable.
Many thanks in advance
 Post subject: Re: Doorbell wires
PostPosted: Wed Nov 28, 2018 6:51 pm
Has thanked: 41 times
Been thanked: 1470 times
You should never "Bridge" (as you put it) a transformer. Doing so in effect puts a dead short circuit on it causing it to over heat and possibly catch fire.
If the transformer is no longer required, remove the mains supply (either by switching it off or removing it's adjacent fuse) then connect the two wires that were connected to it together.
If it will work or not depends what is on the other ends of the cables.
But I am under the impression that ring doorbells use the existing transformer?
PostPosted: Thu Nov 29, 2018 9:06 am
Thank you for your reply.
Sorry for not being clear, I now have a 24v transformer in my fuse box to power the ring but I need to bypass the power to the mechanical sound.
On the photo, it shows 4 wires each connected to terminals 0,1,2,3,4 and the instructions are as follows.
Identify your doorbell’s power source
The wires on the left (0 and 3) are the wires that power
your doorbell’s physical mechanism (or in electrical
terms, its solenoid or coil), making it produce sound.
If you look closely, you can see thin wires from terminals
0 and 3 going to the hidden solenoid.
By contrast, terminals 1 and 2 are connected directly
to each other via a thin wire (meaning they aren’t
providing power to your doorbell).
In my case, I have 6 wires as per the attached photo so I'm unsure of the wires I need to connect as per the instructions to bypass my doorbell.
PostPosted: Thu Nov 29, 2018 7:32 pm
I am confused? :?
You want to install a ring doorbell, you want to bypass your existing transformer, but you post a picture of your door bell.
