It is currently Mon Apr 22, 2019 5:14 pm
PostPosted: Sun Nov 25, 2018 9:36 pm
So I have a new Thermostat for my Combi boiler, Worcester Bosch Greenstar 25si compact. The Thermostat is the Hive, just like this one: https://www.screwfix.com/p/hive-active-heating-thermostat/4632j
Can any one help me figure out how to connect this? I have attached some pics of the connectors in the boiler. And the connectors for the Hive are as follows:
N permanent neutral
L Permanent live
1 Common
2 Heating off(NC)
3 Heating on (NO)
4 unused
PostPosted: Sun Nov 25, 2018 10:58 pm
Has thanked: 41 times
Been thanked: 1470 times
am i right in saying at the minute you have no room stat? and also could you post an in focus 2nd picture. (1st one is fine)
PostPosted: Mon Nov 26, 2018 7:34 am
I will post a better pic in a short while.
I think I have a room stat, I bought a package that contains 1x Hive thermostat, 1x receiver and 1x hub.
PostPosted: Mon Nov 26, 2018 8:39 am
Ok here is a better pic
PostPosted: Mon Nov 26, 2018 6:39 pm
TBH no idea what the parts are on the 2nd picture.
(I assume that your hive is fitted and has cables)
First of all, take the white link out from L to CH
L on the boiler to L on the hive
N on the boiler to N on the hive
L on the boiler to 1 on the hive **
CH* on the boiler to 3 on the hive
*CH is yellow terminal you took the white wire from at the start.
** You could link from L to to 1 on the hive
Post pictures before you switch it back on.
All you are doing is using the hive to tell the boiler its hot enough, dont turn the heating on, it does this by the removal of the white wire from the CH terminal. If its "dead" the heating will be off, if it's "live" the heating will come on. Just like a light switch.
PostPosted: Tue Nov 27, 2018 3:36 pm
Ok I think I'm ready to go. Obviously I'll put some electrical tape over the bare wire connected to the CH.
PostPosted: Tue Nov 27, 2018 7:20 pm
NO!
PostPosted: Tue Nov 27, 2018 10:41 pm
Under no circumstances can you ever use the earth wire as anything but an earth wire.
See the option **
You should also use the L & N on the Orange terminal block NOT the White one.
and as before post a picture before you switch on
You could kill some one with what you have done.
