It is currently Tue May 21, 2019 2:17 am
PostPosted: Sat Nov 24, 2018 5:06 pm
Has thanked: 1560 times
Been thanked: 3912 times
Basically I've got a few 1970's dining chairs that will need putting back into service Christmas day.
A few joints (dowelled) have opened up so the chairs are a wee bit wobbly so what glue would be best to sort this ?
(Preferably summat I can pick up from screwfix or somewhere easy to get to)
TIA
PostPosted: Sat Nov 24, 2018 5:21 pm
Has thanked: 107 times
Been thanked: 308 times
I've used cascamite in powdered resin form, avail Amazon, you can mix with cold water to a paste or thinner but have damp rag to wipe of excess as it is white and obvious; also have clamps ready or a tourniquet system ready; I use those rubber cups you get with persil washing liquid to mix it as always have a few spares.
PostPosted: Sat Nov 24, 2018 5:23 pm
Has thanked: 710 times
Been thanked: 2043 times
can you get them apart ??
at best you will get another year or two out off them as the old glue sinks into the wood so stops new glue penetrating :dunno:
Has thanked: 65 times
Been thanked: 686 times
gorilla glue is good mind the foaming stuff tho, unless its well clamped
https://www.screwfix.com/p/gorilla-glue ... 32ml/83299 or https://www.screwfix.com/p/gorilla-glue ... 36ml/43424
https://www.screwfix.com/p/gorilla-glue-115ml/54593 this is the foaming one, I have stuck stone and brick back together with this stuff
I used to use Titebond (green label) but like anything that's good they went and changed it
Failing that good ol evo-stik exterior (blue bottle)
PostPosted: Sat Nov 24, 2018 5:47 pm
Has thanked: 104 times
Been thanked: 267 times
aeromech3 wrote:
I've used cascamite in powdered resin form.....have damp rag to wipe of excess as it is white and obvious.
White and obvious which is why I normally mix a bit of burnt umber powder into it to get a more similar colour to the timber or finish.
PostPosted: Sat Nov 24, 2018 8:38 pm
Has thanked: 795 times
Been thanked: 895 times
Job & Knock suggested this one when I asked a few weeks ago. He also said, 6 months life if you pump the air out of the bottle. I started by asking for the more complex glues ... happy with it so far, mind you I did not fix any chairs but now that you mention it I have at least one that needs it.
PostPosted: Sun Nov 25, 2018 9:01 am
I've used that glue before . Good stuff unless you only use it occasionally in which case you'll probably waste more than you use. Saying that I do have a bottle that must be over a year old . Nearly at the end of it now though. It had started going off from the top but still liquid at the bottom . I got to the deccent stuff by cutting a little hole in the side of the bottle , in fact I've done this a number of times. Messy but at least I get a bit more use out of it .
