It is currently Tue Apr 23, 2019 11:11 pm
PostPosted: Fri Nov 16, 2018 10:04 am
Has thanked: 6 times
Been thanked: 1 times
Hi All, Really useful tips on these forums so great place to find stuff out. I am a DIY dabbler so need a little advise please.
My question is I have been using 15mm solder rings to fabricate a central heating run. I think my last joint was not mated fully into the elbow joint. I was joining the other end and it melted the solder to the pipe. I now know I should have wrapped it with a wet rag or just been more careful. :oops:
From my measurements it is about half way in so maybe 7mm short. The joint is good as far as I can see but will the pipe not being fully inserted into the elbow cause a problem?
I will have to re-do the whole lot otherwise I guess.
I have not connected it up to the central heating yet.
Thanks in advance, Stewart
PostPosted: Fri Nov 16, 2018 10:34 am
Has thanked: 656 times
Been thanked: 1862 times
I think even though it is a pain, it will be ten times worse fixing it if it weeps after it is all connected. I am sure you know that a bit of time now will save you a lot of grief in the future if it goes bad. Cut it out an replace the defective joint now. Good luck :thumbright:
Painting with BIN
For this message the author dewaltdisney has received gratitude : StewartP
PostPosted: Fri Nov 16, 2018 11:00 am
Thanks DWD. I was kind of thinking that would be the best approach but was hoping I could get away with it. At least I will get more practice and be a bit more careful in future. :salute:
PostPosted: Fri Nov 16, 2018 11:31 am
Yes, I have been there and done that. I find that if you take a chance you get punished for it :lol:
Painting with BIN
PostPosted: Fri Nov 16, 2018 11:36 am
Has thanked: 1235 times
Been thanked: 1110 times
And you know it's there waiting to leak. I'm with DWD. It's less pain to do it properly while it's drained, and you have the kit there, than to have to do it later.
For this message the author Dave54 has received gratitude : StewartP
PostPosted: Fri Nov 16, 2018 1:29 pm
Has thanked: 45 times
Been thanked: 750 times
If there is plenty of solder in the joint it is unlikely to leak but for me it would depend on the circumstances. If I were burying or hiding the joint, I would absolutely re-do it. If the joint were going to be fairly easy to access and monitor I might just chance it as it wouldn't be any more work to repair it if it did leak then repair it now.
For this message the author Rorschach has received gratitude : StewartP
PostPosted: Fri Nov 16, 2018 5:03 pm
Has thanked: 3 times
Been thanked: 135 times
we throw all bad fittings no matter what and then use fresh cleaned and lightly fluxed new fittings. never re-use the bad fitting.
clean and wire wool and flux the pipe ends and use a small mirror to check the back of the soldered joint to see if its made. if you can see a rim of solder all round it should be made.
pencil mark the pipe for its insert length then you can be sure its in the fitting hub.
For this message the author wes56 has received gratitude : StewartP
PostPosted: Sat Nov 17, 2018 12:21 am
Has thanked: 228 times
Been thanked: 299 times
For what it's worth, I'm with everyone else here. It's *probably* okay as it is, but a new yorkshire elbow is, what, 40p? A flooded house considerably more expensive! Definitely not worth the risk.
For this message the author chrrris has received gratitude : StewartP
PostPosted: Thu Nov 22, 2018 9:54 am
Hi All, I took the consensus view which was to do it again. It took me half the time to re-fabricate the run with new joints (so I'm improving my skills) and I was glad I did for my peace of mind. No leaks when I tested so well chuffed with myself. Small victories eh!
Many thanks for all the replies and lots of good advice.
For this message the author StewartP has received gratitude : dewaltdisney
PostPosted: Thu Nov 22, 2018 12:14 pm
Thanks for letting us know Stewart, I am glad it turned out good in the end. :thumbright:
Painting with BIN
