It is currently Mon Apr 22, 2019 7:20 pm
PostPosted: Thu Nov 15, 2018 1:02 pm
Has thanked: 45 times
Been thanked: 750 times
Have to do a repair to some outdoor woodwork (fence parts mostly). The wood is old, going a little bit soft and screws/nails will probably not hold well on their own. I know it's a bit of a bodge job and it will need to be replaced but it's not the best time of year and there is a baby on the way so the plan is to tidy it up and squeeze a little more life out of it.
I am guessing something polyurethane based as they cure with moisture, all suggestions appreciated though.
PostPosted: Thu Nov 15, 2018 8:20 pm
Has thanked: 2 times
Been thanked: 7 times
Many options as I see it.
If possible cut out the bad material. Or use a wood hardener first. Use a bolt to go right through to the other side.
If the wood is not strong enough to hold a screw then I doubt it is up to just a bit of glue on the surface.
Hope that helps
tim
PostPosted: Thu Nov 15, 2018 8:25 pm
From what I have been told it's only a bit of cosmetic capping that is loose, nothing structural. Not seen the job yet but I am imagining there is not a lot to fix into based on the last little repair I did.
PostPosted: Thu Nov 15, 2018 8:49 pm
Has thanked: 141 times
Been thanked: 174 times
If I was asked to do a job like that I would use something like this;
https://www.toolstation.com/shop/Adhesi ... 0ml/p69243
It has a high initial grab and can be used on wet surfaces so it will do the job even on some crappy wood.
Mike
For this message the author London mike 61 has received gratitude : Rorschach
Users browsing this forum: steve2095 and 2 guests
