It is currently Tue Apr 23, 2019 11:11 pm
 Post subject: kinked copper pipe
PostPosted: Mon Nov 05, 2018 12:29 pm
Has thanked: 3 times
Been thanked: 1 times
hi all,
I was attempting to install my new shower valve. the actual install went ok. I had a small leak so I naturally tightened the nut. it seemed I overtightened it and the olive compressed or kinked the pipe slightly. can I carry on with the install or will this cause an issue?
im breaking for lunch now
thanks
 Post subject: Re: kinked copper pipe
PostPosted: Mon Nov 05, 2018 12:48 pm
Has thanked: 656 times
Been thanked: 1862 times
I think I would try undoing the nut and wrapping a load of PTFE tape around the olive and re tightening. If you really feel it is buggered then now is the time to cut out a section and replace the pipe and start over. It is the danger of over tightening. We have all done it.
Good luck sorting it :thumbright:
Painting with BIN
PostPosted: Mon Nov 05, 2018 12:58 pm
thanks DWD, I've attached some photos. how many turns of PTFE would you advise, and when tightening, how much is too much?
thanks
PostPosted: Mon Nov 05, 2018 2:01 pm
I think that you should pipe slice that off and put in a fresh section of pipe. It looks like you have enough room. I always wrap a couple of times around the olive and tighten half a turn more when it gets stiff. It allows a little more of a turn if it weeps.
Painting with BIN
PostPosted: Mon Nov 05, 2018 4:06 pm
hi DWD, I tried above, no luck! still leaking.
ive attached a photo of the valve installed. if i splice the ends as you advised above, i doubt it would reach to connect to the inlets of the valve.
thanks
PostPosted: Mon Nov 05, 2018 4:47 pm
Has thanked: 840 times
Been thanked: 941 times
Cut the pipe off below the bend and start again with a new bend etc.
Dave
www.drlgas.co.uk
PostPosted: Mon Nov 05, 2018 7:51 pm
Has thanked: 234 times
Been thanked: 192 times
There's only one way to do a job like this and it's to do it properly. If you leave it and it starts leaking......
