It is currently Sun Apr 21, 2019 7:38 pm
PostPosted: Fri Nov 02, 2018 5:47 pm
Has thanked: 2 times
I am doing exactly the same as this post ( http://www.ultimatehandyman.co.uk/forum1/temporary-wooden-table-top-extension-t61237.html ) - making a temporary table top for Christmas. My question relates to the storage of the extending pieces.
I am using 25mm plywood and have cut a standard 8'x4' sheet in two for easier storage. Under each 'leaf' will be a glued and screwed U-shaped wooden frame, sized to fit the current table top, and the two 'leaf' parts will be clamped together on each side.
After using the extender it will probably be stored in the garage ... but it only just occurred to me that the dampness is likely to warp the plywood. So I was hoping there might be a method to seal the plywood to allow it to resist any moisture and avoid warping. Has anyone here successfully stored plywood in a garage without suffering from warping and if so how did they do that?
Paul.
PostPosted: Fri Nov 02, 2018 6:16 pm
Has thanked: 656 times
Been thanked: 1861 times
Would they not slide under a bed when not in use? The 'U' shape does not have to be very thick it only stops drift.
Painting with BIN
For this message the author dewaltdisney has received gratitude : Adendum
PostPosted: Fri Nov 02, 2018 8:50 pm
Has thanked: 141 times
Been thanked: 173 times
Perhaps if you clamped the 2 face sides together in storage there would be less likely to warp.
Mike
For this message the author London mike 61 has received gratitude : Adendum
PostPosted: Fri Nov 02, 2018 9:33 pm
Yeah, storing under the bed AND clamping them might be a solution but we're downsizing soon and I am pretty sure we'll need every inch in doors, so an outdoor (garage) solution would also be welcome...if anyone has any ideas.
For example, if I sealed the panels would that work?
PostPosted: Sat Nov 03, 2018 9:54 am
Has thanked: 103 times
Been thanked: 260 times
Held to the ceiling with turnbuckles?
