It is currently Sat Feb 23, 2019 5:58 pm
 Post subject: Wallpaper glue help!
PostPosted: Thu Oct 25, 2018 8:55 pm
Has thanked: 30 times
Been thanked: 3 times
I've stripped two walls of wallpaper and all come off lovely however there are lots of patches of glue residue left behind. Tried vinegar and water, hot soapy water and sugar soap and nothing is removing it. I want to paint these walls but don't fancy painting the paste! Is there anything I can do or product I can buy to clean this or shoukd I just re paper!!
Sent from my SM-G930F using Tapatalk
 Post subject: Re: Wallpaper glue help!
PostPosted: Thu Oct 25, 2018 10:16 pm
Has thanked: 914 times
Been thanked: 480 times
If you don't remove every little bit of residual wallpaper paste you run the risk of the paint crazing so, in my experience, the easiest and most effective solution is to hang lining paper, and then paint it.
PostPosted: Thu Oct 25, 2018 11:04 pm
Thanks, I'd rather avoid lining it if I can, must be something out there. Anyone use zinnser dif for this purpose?
PostPosted: Thu Oct 25, 2018 11:35 pm
Has thanked: 766 times
Been thanked: 858 times
No. For a DIYer labour is cheap, lining paper has its uses whether it is to save time or to hold together crumbly plaster (as in lathe plaster) and similar. Other than that, lining paper tends to be a bodge in my mind. Lining paper shows - at least I see it - so it is the last solution before skimming whether with plaster or decorators skim products. Decorators should be able to do a skim coat, they do so in Europe and still wear white clothes and I am not that good at it but there again I am not time served.
To the OP. What you need is large bucket (x2 ideally), car style wash sponges (also x2 ideally), sugar soap powder as a safe add on (optional but you might as well), wallpaper scraper (x1 but the more you have the better it is to find the one you like) like this https://www.toolstation.com/shop/p66273 or this https://www.toolstation.com/shop/p96313 etc., and scotchbrite like so https://www.3m.co.uk/3M/en_GB/company-u ... 499&rt=rud there are other non-brands too :mrgreen:
You use one bucket with warm water and sugar soap + sponge and get an area wet top to bottom. Go back to it a number of times 2 -3 times over 15 minutes. With that size sponge the water will be dripping to the floor... after 15-30 minutes the paste will be activated and that is when you scrape it off, use the scotchbrite as well once you have scrapped. If the wall has paste it will feel slimy and slippery but once it is clean it will not be easy to slide your finger tips on the wall. You don't need a lot of elbow grease or hard work, you need to let the water activate the paste. Once you get the method you can have cups of tea whilst waiting.
The second bucket/sponge warm water and spare scotchbrite are needed if you use sugar soap as it has to be rinsed off ... by the time you rinse things off (and use clean water as much as you can) there will be no paste residue left.
After that make the surface as good as you want (sand/fill/sand) etc.
I am a DIYer :-)
EDIT. If you strip any more walls, use the two buckets approach from the start. Don't take the paper off and then think what you will do next, as you remove the "wet" paper keep wetting the wall, scraping it and washing it down. The trick is to get everything moist and not to do it in stages.
PostPosted: Fri Oct 26, 2018 6:48 am
Quote:
Lining paper shows
Only if it's not done properly.
For this message the author Tom d'Angler has received gratitude : Have Brush Will Travel
PostPosted: Fri Oct 26, 2018 7:26 pm
Has thanked: 106 times
Been thanked: 303 times
Would a steamer loosen the glue (if it is standard water based glue)? Set u back about £30!
PostPosted: Fri Oct 26, 2018 8:08 pm
Steamers are reputed to like blowing off plaster (the skim coat).
PostPosted: Fri Oct 26, 2018 10:12 pm
Has thanked: 244 times
Been thanked: 249 times
No one mentioning Zinsser Guardz....
PostPosted: Fri Oct 26, 2018 10:14 pm
I assume the surface is not good enough (bumpy with paste).
PostPosted: Sat Oct 27, 2018 8:11 am
The walls aren't bumpy just an occasional haze. What is gardz?
PostPosted: Sat Oct 27, 2018 9:48 am
http://www.zinsseruk.com/product/gardz/
Definitely need to remove as much as you can first like Ochaye says.
Using a flat filling blade helps.
