It is currently Fri May 24, 2019 8:47 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
 Post subject: Lighting Wiring
PostPosted: Thu Oct 18, 2018 11:31 pm
Has thanked: 5 times
I had some work done on some kitchen lights (they switched one light into 4 spots). I have reattached 2 lights on a 2 gang switch in the living room and when turned on they turn all 4 spots turn on!
The living room lights are wired as per photos below...
Any help would be much appreciated.
 Post subject: Re: Lighting Wiring
PostPosted: Fri Oct 19, 2018 5:28 am
Has thanked: 41 times
Been thanked: 1480 times
Sorry, your question is?
If all 4 lights come on at the same time they can not be wired as per diagram. The diagram is correct, for two single lights.
PostPosted: Sat Oct 20, 2018 6:33 pm
Hi, thanks for your reply.
When I turn the living room lights on, the kitchen lights come on but at about half the brightness. Is there a simple reason/fix?
The wiring diagrams are for the living room.
PostPosted: Sat Oct 20, 2018 6:42 pm
Has thanked: 1561 times
Been thanked: 3914 times
you have wired the kitchen lights incorrectly Pics of the wiring please (ceiling and switch)
PostPosted: Sat Oct 20, 2018 6:48 pm
I would say the neutral is in the wrong terminal, and it's actually back feeding via the other lights.
PostPosted: Sat Oct 20, 2018 6:57 pm
Switches if that helps
File comment: Kitchen
File comment: Living Room
PostPosted: Sat Oct 20, 2018 6:59 pm
Issue is deffo not at the switches then. Must be the rewiring at the light point that you re wired. Pics when you can.
PostPosted: Sun Oct 21, 2018 11:16 am
Please see below photos,
Those spots were awkward to get out!
I didn't wire the spots, only the replacment lights in the living room, with the wiring shown in my original post.
Cheers
File comment: junction box - angle 2
File comment: junction box - angle 1
File comment: 1 of 4 kitchen spots
PostPosted: Sun Oct 21, 2018 12:34 pm
Nice (and clear and in focus) that the pictures are they don't help that much. :?
But let me see if I have this right,
Two spotlights were taken down, and when you put them back, when you switch on one, the other comes on at 50%?
PostPosted: Sun Oct 21, 2018 1:30 pm
Has thanked: 65 times
Been thanked: 687 times
possably a bad fitting - remove a bulb at a time and test
edit. or is that supposed to be 2 way switching from the lounge - what did the double switch use to do ?
if you turn on the lounge lights and the kitchen lights what happens ? or just the kitchen ones ? are the new lights led bulbs ?
PostPosted: Sun Oct 21, 2018 2:13 pm
Sorry guys let me try again
Living Room (I have just wired)
2 lights
2 gang switch (1 way? left switch controls left light, right controls right light)
Kitchen (pre existing)
4 spots joined by junction box
1 gang (1 way)
When I turn on one living room light, the kitchen lights come on at approx. half brightness.
When I turn on both living room lights, they don't work properly, and kitchen lights come on as above.
If the kitchen lights are on, the living room lights won't function at all
:scratch:
PostPosted: Sun Oct 21, 2018 4:50 pm
As I said in the first place they are NOT wired as per your diagram.
You have got one wire wrong, my guess is you have a neutral connected to a switched live.
It has to be where you reconnected the lights since they were working as they should before you did any thing.
PostPosted: Sun Oct 21, 2018 5:00 pm
Pics of the rewiring that you did please.
PostPosted: Sun Oct 21, 2018 5:16 pm
How are the kitchen lights wired, inline with one another ? the JB in angle 1 looks to be correct, left pair are the ring in/out - right side top cable is your switch, The lower is connection to the lights (black and brown)
As I said above remove a bulb at a time in the kitchen
PostPosted: Sun Oct 21, 2018 7:01 pm
Will give it a go Bob
pics below of the living room wiring
File comment: light 2
File comment: light 1
