It is currently Sun Feb 17, 2019 8:14 am
 Post subject: Hanging a Mirror...
PostPosted: Sun Oct 14, 2018 10:38 pm
Been thanked: 1 times
So my builder has ran a gas pipe and wires (see images) down a wall and then created a small false wall over the top with plasterboard.
The issue I have now is that the boss wants a 30kg mirror hung onto it. I don't where the stud work is behind, I'm worried about hitting the pipe/wires and worried about whether the plasterboard will take the weight.
My best guess so far it to hang it from two hollow wall bolt anchors near the top centre. That should miss everything. Then perhaps support it with a long 'L' shaped bracket underneath the bottom edge of the frame.
Anyone got any better suggestions??
File comment: After
File comment: Before
 Post subject: Re: Hanging a Mirror...
PostPosted: Sun Oct 14, 2018 10:45 pm
Has thanked: 40 times
Been thanked: 1426 times
Yes, don't fix it to the plasterboard it will fall down. At least you have a good picture of the pipes and cables, you should easily be able to figure out where they are, so don't fix any less than 30cm from the left.
PostPosted: Sun Oct 14, 2018 11:44 pm
Has thanked: 410 times
Been thanked: 1497 times
Is there anything on the mirror to facilitate hanging? It looks a bit like an old mirror that might have a chain on the back.
If you just need one central fixing, find a stud, put the kids to bed, turn off the telly and tap the wall with the fat end of a pencil, you can easily hear the difference between just p/b and p/b with a stud behind it. The stud should be at least 35mm wide.
PostPosted: Mon Oct 15, 2018 1:49 pm
There's a couple fixing points on the sides about three quarters of the way up. Can't use those directly as one will hit the wires. I could run a chain through them and hang centrally like you suggest. Although that's dependant on there being a stud in exactly the middle.
If there's no stud do you think a hollow wall anchor or two could hold it??
PostPosted: Mon Oct 15, 2018 2:46 pm
Has thanked: 140 times
Been thanked: 167 times
A year or so ago I had the same problem , so I bought myself a set of magnets
https://www.first4magnets.com/circular- ... pull-p6221
To help me find the screws in the stud work.
I have since used them a lot and I find they are the quickest way to find studs without poking holes in walls.
Mike
