It is currently Sat Jan 19, 2019 9:12 pm
PostPosted: Thu Sep 27, 2018 4:00 pm
Has thanked: 875 times
Been thanked: 378 times
I've just changed the oil and filters on my 2011 Peugeot partner van. The van drives great but the engine management light is on. Is there an easy way to turn it off or will I need to get my mate to use his diagnostic gizmo to turn it off?
I'm guessing as I changed the fuel filter it probably thinks the filter is faulty or has water in it.
PostPosted: Thu Sep 27, 2018 4:48 pm
Has thanked: 999 times
Been thanked: 1878 times
Disconnect the battery for 10 minutes and reconnect. This can often clear a fault that’s not really there.
What did you fill the fuel filter with prior to fitting?diesel or injection cleaner?
PostPosted: Thu Sep 27, 2018 5:56 pm
Has thanked: 60 times
Been thanked: 625 times
It needs the codes read it may just be asking for a oil reset after service or it maybe be moaning about a dpf regen
Have you given it a good run after the service and got it nice and warm ?
PostPosted: Thu Sep 27, 2018 8:21 pm
Nothing, I fitted the fuel filter and then drew up diesel through the filter using a hand pump. Van started first time.
PostPosted: Thu Sep 27, 2018 8:22 pm
Well I've driven it about 20 miles but the light is still on. I'll pop down to my pals tomorrow and see what he says.
PostPosted: Fri Sep 28, 2018 11:59 am
not 100% but is there a sensor on the filter and if so did you plug it back it ?
PostPosted: Fri Sep 28, 2018 9:27 pm
it's all sorted. I realised after driving the van for 30 mins the light was off. It must have sorted itself out overnight.
