It is currently Fri Apr 19, 2019 12:09 am
 Post subject: Switch + dimmer
PostPosted: Sat Sep 22, 2018 12:08 pm
I currently have a normal double switch socket. One switch controls the downstairs light and the other controls the upstairs. I am installing a dimmable light feature downstairs but not up. I was just wondering if there is such a thing as a socket with one dimmer and one switch or if I installed a double dimmer would that work?
Also for a normal dimmable feature is it enough to just install a dimmer switch? or do I need to do any other work
 Post subject: Re: Switch + dimmer
PostPosted: Sat Sep 22, 2018 12:20 pm
Has thanked: 18 times
Been thanked: 23 times
You can install a dummy dimmer module on the side you do not wish to dim. They're not expensive and easy to change out.
You might want to check your light fitting and lamp are suitable for dimming or you could get strobing or other issues on the dimmed side.
For this message the author Maz123 has received gratitude : OnlyMe
PostPosted: Sat Sep 22, 2018 2:57 pm
Has thanked: 65 times
Been thanked: 674 times
The simplest way would to use a modular system to make a custom switch
Varilight (do there own and MK compatible) and MK both do grid systems
A grid switch is made up of a switch module(s), a Grid frame and a switch grid aka faceplate
PostPosted: Sat Sep 22, 2018 7:00 pm
Has thanked: 41 times
Been thanked: 1469 times
First of all it is called a switch / switch plate, not a double switch socket. I had to point that out to make your search easier, other wise you will just end up with
Which is a double switched socket.
As said what you want is more commonly known as a "Grid switch You will also need a Grid frame a grid box and a Grid plate
But before you even think about any of that, I should ask the following.
Is your your light fitting able to be dimmed? (not all are)
Why are you dimming a hall lamp?
Get an an echo dot, a phillips hue kit and enjoy. (You just tell alexa to turn the light on or off, no need for a switch :-P )
PostPosted: Sat Sep 22, 2018 7:04 pm
Why use a grid switch when you can just get a normal double dimmer switch and change out one of the modules for a dummy?
PostPosted: Sat Sep 22, 2018 7:33 pm
Because your "off the shelf" dimmer does NOT have a module to be changed. But a grid switch can have any combination you like (Within reason)
Not wishing to be pedantic but of what use would a "dummy" be, since he still wants two switches, one normal on / off switch, the other a dimmer.
PostPosted: Sat Sep 22, 2018 7:38 pm
I'm yet to come across a dimmer that I couldn't change the module on.
It's a dummy dimmer module....in that it looks like a dimmer switch but simply turns the light on and off with no actual dimming function.
PostPosted: Sat Sep 22, 2018 7:57 pm
Link to a suitable dimmer? and your "dummy"
PostPosted: Sun Sep 23, 2018 10:49 am
Most of the double dimmers I have come across are 1 complete module apart from the Varilight VL ones and there on the chunky side and are rotary on/off
s-e no need for a grid box, the frames fit a standard backbox and you just add what ever face you want - long gone are the days of the grids just being in metal clad
PostPosted: Tue Sep 25, 2018 6:52 pm
Approved Electrician
Has thanked: 174 times
Been thanked: 593 times
The dummy switches are these sort of things
https://www.tlc-direct.co.uk/Products/VLMPINT.html
https://www.tlc-direct.co.uk/Products/VLSM.html
ttps://www.sparkswarehouse.com/products ... ush-dimmer
Other makes are available. Personally I do not use them. I tend to use modular plates (as mentioned by Bob) and make whatever switches I need)
