It is currently Fri Apr 19, 2019 9:35 am
PostPosted: Fri Sep 21, 2018 11:13 pm
Has thanked: 1 times
Been thanked: 5 times
Last time I painted a window sill I burnt off all the old paint to bare wood. Sanded it down smooth. Painted with Dulux Trade quick dry undercoat. Followed by 2 coats of Dulux Trade quick dry gloss PBW. It may have been 3 in the end, can't remember.
However the finish wasn't smooth. You could see the grain was raised and was bumpy to touch.
Does this happen because the paints are water based and the wood is soaking up the moisture?
I'm going to be doing another window sill and would like this to have a better finish. What did I do wrong?
Do I need to apply 1 coat of undercoat then sand until smooth and apply a second undercoat?
Thanks in advance
AnthonyImage
Sent from my XT1580 using Tapatalk
PostPosted: Sat Sep 22, 2018 8:31 am
Has thanked: 45 times
Been thanked: 747 times
Probably a combo of not sanding smooth enough in the first place, then lack of sanding between coats of paint causing the grain to raise.
PostPosted: Sat Sep 22, 2018 9:49 am
Has thanked: 786 times
Been thanked: 884 times
:withstupid:
There are lines from the window towards where you are standing for the photo. Are those lines something you can feel with your finger tips or some trick of the photograph with light? If you can feel them certainly more sanding.
Water based paint will raise the grain more than solvent based paints, and you need to sand before the next coat using something like 300ish grade paper and then make sure the surface is perfectly clean (use a tack cloth). The raising of the grain is tiny little spots of wood lifting ... it is not "bumpy".
You should have used Primer, Undercoat, Top coat ... I think you missed the primer but this has got nothing to do with the problem you describe.
Finally, did you stir the paint well? And did you let each coat dry as much as possible, i.e. more than the tin says for recoating time? The opacity does not look any good either.
PostPosted: Sat Sep 22, 2018 10:27 am
Something else that can be a problem (and very hard to solve) with painting softwoods is that when moistened the softer grain raises quickly but takes a while to dry out, whereas the harder grain absorbs moisture more slowly and doesn't raise as much.
What ends up happening is the soft grain plumps up, you sand things smooth and level and over time the soft grain dries out and sinks back down which is now below the level of the harder grain leaving you with an uneven surface. Trying to sand this smooth can be a real pain as the harder grain resists the sandpaper and if you use a sanding surface that is too soft you end up just digging out the softer grain even more.
PostPosted: Sat Sep 22, 2018 11:37 am
Ok,I didn't sand between coats. By the sounds of it that's where I've gone wrong.
The sill was perfectly smooth before undercoat. And it was a couple of days between coats.
I have some zinsser bin. Should I use this as a primer before the undercoat? Or some other primer?
So would this be correct?
1 primer
2 undercoat
3 sand with 300 then first coat
4 sand with 300 then second coat
The vertical thin lines are from my mobile. It didn't like the led torch I was using.
Anthony
PostPosted: Sat Sep 22, 2018 11:53 am
I've just done a Google for primer.
Would dulux trade quick dry wood primer undercoat be a better option than using the zinser?
Would I need to sand after applying this primer undercoat?
PostPosted: Sat Sep 22, 2018 2:39 pm
Yes use the Dulux stuff. You need primer or primer/undercoat if you have bare wood.
You need something thicker for the first sanding of the wood ... after you finish scraping. 120grade followed by 180 ??? (a lot depends how much sanding is needed and how heavy handed you are). You are better off using a sanding block example when doing the first sanding.
These are example for in between coats papers http://www.oakey-abrasive.co.uk/products/between-coats/ B&Poo used to do a pack with a selection of sheets but I have no idea what it has now.
Whether you need to sand in between every coat or not. Raised grain feels like 1 or 2 days growth of whiskers/beard, and if you are a woman all I can suggest is go around and run the back of your fingers at random blokes' faces. You will soon get the idea of what scrapes your skin and what doesn't. If the wood feels rough, sand in between coats and clean afterwards.
You only have to remove the sticky out bits not be heavy handed.
For this message the author OchAye has received gratitude : demusss
PostPosted: Sat Sep 22, 2018 5:06 pm
Brilliant thanks for the advice.
Guys will look at me daft if I start feeling up their stubble :)
Anthony
For this message the author demusss has received gratitude : OchAye
PostPosted: Sat Sep 22, 2018 6:57 pm
You might look equally daft if you use the back of your hand to "feel" the wood and then feel your face, sand and repeat.
BTW. It was damn hard at my working life to try and learn not to assume gender. Often still is ::b
PS. Unfortunately the brush aficionados are not posting any more. We told each other stories of brushing "gently" our lips with new brushes (in the bathroom) and then practicing dry cutting in on the inside of the bathroom door.
