It is currently Mon May 27, 2019 9:10 am
PostPosted: Mon Sep 17, 2018 9:34 am
Has thanked: 949 times
Been thanked: 413 times
What's the best stuff to use for filling a gap between skirting and a laminate floor? I normally use SF's no nonsense caulk but wonder if there is a better product?
The gap is only about 2-3 mm but there's complaints of draughts.
PostPosted: Mon Sep 17, 2018 12:02 pm
Has thanked: 237 times
Been thanked: 196 times
Surely with the bounce in a laminate floor the caulk would simply break up and the draughts would return.
Is edging strip not an option?
Clear silicone?
PostPosted: Mon Sep 17, 2018 2:55 pm
Sorry I meant silicone not caulk.
What's the best silicone to use? I normally use the no nonsense stuff but someone suggested another brand that apparently has more flexibility but I can't recall the name he mentioned.
Edit: I just remembered it's Ever build brand. It has a flexibility factor of 25% where as the one I had only had 12%.
PostPosted: Mon Sep 17, 2018 3:34 pm
Has thanked: 8 times
Been thanked: 34 times
Just remember you can't over paint silicone. What about this:
https://www.sealantsandtoolsdirect.co.uk/silicones_and_sealants/caulk_and_flexible_internal_acrylic_sealant/everbuild_195_siliconised_acrylic_sealant_caulk_white_c3_195we_P23395.html
PostPosted: Mon Sep 17, 2018 5:07 pm
Looking at the photo of that stuff it states on the bottom of the tube 'flexibility factor 12.5%'. The exact same as the normal stuff.
I think this is the stuff he meant. It has a flexibility factor of 25%
https://www.toolstation.com/shop/Adhesives+%26+Sealants/d180/General+Sealants/sd2350/Premium+Building+Silicone+310ml/p97204
PostPosted: Mon Sep 17, 2018 5:19 pm
Has thanked: 76 times
Been thanked: 10 times
I would say that the best stuff to use is a two part collaboration called Scribe and Jigsaw!
Never fails :)
PostPosted: Mon Sep 17, 2018 6:36 pm
Has thanked: 1002 times
Been thanked: 1897 times
Never fails :)
If the sub floors that bad you need to scribe the skirting to the laminate you shouldn’t even be laying laminate in the first place...
PostPosted: Mon Sep 17, 2018 7:45 pm
Has thanked: 3 times
Been thanked: 20 times
Bit left of field this !
Having recently fitted skirting in my new kitchen down onto porcelain tiles which are bedded on tile cement onto XPS under floor heating insulation I was concerned about how to finish , being a bit of a “flash gap fan” I actually had a load of 5mm UPDM glazing double sided tape and put this on the bottom of skirting as I fitted it , worked a treat , then even used it on the bottom of the kick boards under the cupboards !
I await a severe talking too LOL , crack on guys !
PostPosted: Mon Sep 17, 2018 8:16 pm
Woah!!! Lots of people making assumptions here.
First of all the skirting and laminate were laid years ago. I had nothing to do with it. The person feels there's a draught coming from the small gap at some points in the skirting. Probably only a couple of mm but none the less she's asked me to fill it.
PostPosted: Mon Sep 17, 2018 8:23 pm
Never fails :)
Tell that who ever fitted it smart arse :-)
PostPosted: Mon Sep 17, 2018 8:49 pm
On a uniform gap of a couple of mm I’ve never had any bother using everbuild silicone.
I just use the closest colour match to the skirting,which in 90% of cases is white.
One of those fugi kits is handy for this job as well.
PostPosted: Mon Sep 17, 2018 9:15 pm
Cheers Stevie. I have one of the fugi kits. I was just concerned about expansion of the wood.
PostPosted: Tue Sep 18, 2018 10:02 am
Has thanked: 796 times
Been thanked: 896 times
2-3mm gap ... me thinks you are overthinking it.
PostPosted: Tue Sep 18, 2018 10:36 am
Has thanked: 416 times
Been thanked: 1566 times
:withstupid:
What's the difference in expansion/contraction between 12% & 25% over 2-3mm?
(it's about 0.3mm)
PostPosted: Tue Sep 18, 2018 8:57 pm
It turned out some parts were about 6-7mm so I bought the 25% flexibilty factor to be on the safe side. I was just going by what the lady said. It turned out she was underestimating size. Who knew :wink:
