It is currently Fri Apr 19, 2019 9:34 am
PostPosted: Sat Sep 15, 2018 12:03 am
Has thanked: 28 times
Hello All,
Is any one still tiling on top of ply. I believe it is frowned upon now but I can not get my head around these new alternatives.
Has any one used things such as no more ply and is it any good.
Cheeers
PostPosted: Sat Sep 15, 2018 12:15 am
Has thanked: 709 times
Been thanked: 2040 times
the now usual i get round here is 5.5/11.5mm ply is complete carp if wet as the surface layers are micro thin
they also seem to dellamminate very quickly :dunno:
For this message the author big-all has received gratitude : colo
PostPosted: Sat Sep 15, 2018 10:08 am
Has thanked: 655 times
Been thanked: 1857 times
It is a no go with ply really as the tiles invariably pop off. It is best to use something like Aquapanel or Hardibacker, cement based board, in the wet areas and plasterboard in the dry zones. The tiles will go on much better and stick, just be a bit careful if you are using these modern massive size tiles as weight is a factor. It is more or less the same process to screw up boards as it is ply.
Painting with BIN
For this message the author dewaltdisney has received gratitude : colo
PostPosted: Sun Sep 16, 2018 12:14 am
Hello and thanks for the replys.
I think I should have been clearer in my explanation.
I am referring to over boarding the floor with 12mm wbp ply.
Would it be OK if I was to screw it down every 100mm to stop it moving.
The tiles are 600x300 porcelain.
Thank You for any advice.
Col
PostPosted: Sun Sep 16, 2018 7:37 am
Has thanked: 1547 times
Been thanked: 3891 times
If you must tile directly to ply then at least use a primer such as https://www.toppstiles.co.uk/tprod8763/ ... -1ltr.html
Other brands available.
For this message the author wine~o has received gratitude : colo
PostPosted: Thu Sep 20, 2018 6:32 pm
Thanks you for the link and advice Wine~o,
I got a 5ltr in case I use the ply on the floor. However, I am listening to the advice off you men on here and I think the ply I already bought to do the job might get the elbow and I will use No More Ply instead.
ATB
Col
PostPosted: Thu Sep 20, 2018 6:41 pm
No more ply is a better option
PostPosted: Thu Sep 20, 2018 10:33 pm
Thank you.
ATB
Col
PostPosted: Fri Sep 21, 2018 10:27 am
Has thanked: 107 times
Been thanked: 308 times
"I got a 5ltr in case I use the ply on the floor".
Must be a Church Hall size for that amount?
PostPosted: Sat Sep 22, 2018 11:11 pm
I thought it would be better value to buy 5ltr rather as I need some for mixing in cement motor but I think I might have overestimated as usual.Ha.
PostPosted: Wed Oct 17, 2018 3:08 pm
Has thanked: 36 times
Been thanked: 10 times
We had a eastern european builder tile our bathrooms and he used plywood. All the tiles came loose in next to no time.
Not sure if it was the ply bending with moisture or that the adhesive just didn't stuck to the tile.
PostPosted: Wed Oct 17, 2018 3:09 pm
Not sure why anyone would use ply. and not the "no more ply" backer boards. it's not all that more expensive than plywood.
PostPosted: Fri Oct 19, 2018 10:07 pm
Old School Chippie
Has thanked: 799 times
Been thanked: 1594 times
On commercial jobs we still use plywood - but we are covering sometimes hundreds of square feet. We always screw down on either 100mm or 150mm centres with the heads fully sunk (this may require a special screw such as Hilti whiterock screws if you aren't willing to pilot and countersink). It isn't sealed before it goes down, but then if there is any question about the screed/concrete beneath it (if that's what is there) then that gets a coat of green liquid DPM before we start (allowed to dry overnight if possible). Tilers seem to universally favour rapid set adhesives with Bal, Ball, Ardex and Mapei used most commonly in my experience
