It is currently Thu Feb 21, 2019 1:04 pm
PostPosted: Fri Sep 14, 2018 5:52 pm
Has thanked: 2 times
I’ve put two coats on as has been recommended on valspar painted walls. I’ve done one coat of matt emulsion and I can see a thick white outline from where I cut the stain blocker in. I was planning to do two coats but I really don’t think this will cut it, it just doesn’t want to adhere.
So my question is... was I supposed to use a base coat on top of the stain blocker? Would really appreciate some advice before I throw more expensive paint after bad
Thank you in advance
(That’s with one coat of paint!)
PostPosted: Fri Sep 14, 2018 6:32 pm
Elephant Man
Has thanked: 606 times
Been thanked: 1366 times
:welcomeuhm:
Dulux Trade Stainblock does work well but draws any staining into it, leading you to think it may have failed. I'm sure it's a 6-hour re-coat period for this product and it's important it has properly dried before any emulsion is applied.
Is it Valspar Trade emulsion you've used, as the retail equivalent of any trade brand, can have quite awful opacity.
Nihil expectore in omnibus
For this message the author dynamod has received gratitude : Meh_of_House_RoF
PostPosted: Fri Sep 14, 2018 6:53 pm
Been thanked: 15 times
I have recently done one of the Valspar smelly paint cover up jobs procedure as follows
I flattened all walls (deros)
applied first coat Dulux stainblock to all walls, then left overnight (B & Q said 45 min recoat time) Dulux say min 4-6 hours
then applied second coat Dulux stainblock to all walls,
This was then left for one week
Two coats of Johnstones coverplus mixed to a Little Greene colour was used,
this was done approx six weeks ago, and at present everything seems to be ok.
The spec above was from Valspar so I followed it to the letter so if the problem comes back it is there problem again not mine.
For this message the author bitzz has received gratitude : Meh_of_House_RoF
PostPosted: Fri Sep 14, 2018 7:08 pm
Thank you, that’s helpful to know it should theoretically work....
Originally had valspar. Applied one coat of primer, second coat around 10 hours later. Left to cure for about 4 weeks
Top coat is farrow and ball. I’ll persevere with more coats and hope for the best.
PostPosted: Fri Sep 14, 2018 9:57 pm
Has thanked: 19 times
Been thanked: 14 times
How is this the first I’m hearing of it? Just read Valspar paint smells similar to cat p*ss after a couple of weeks?
That’s bloody terrible.
PostPosted: Sat Sep 15, 2018 6:44 pm
Has thanked: 100 times
Been thanked: 122 times
I've used the Valspar v700 emulsion on a number of jobs over the last few years, including last week, and had no trouble with smelly paint.
PostPosted: Sun Sep 16, 2018 7:01 pm
Three coats have done the trick! Thank you guys!! People were saying I should put undercoat on and then repaint so you’ve definitely saved me some time
