It is currently Sun May 26, 2019 12:21 pm
PostPosted: Tue Sep 11, 2018 6:55 pm
Has thanked: 35 times
Been thanked: 28 times
Hi
I have a room of about 3.5m x 3m on the first floor and am restoring the floorboards, however there is an area roughly 1m x 1.5m floorboards are damaged as they have been removed and put back for whatever reason. I can't get the exact height and size t&g floorboards so I have to do with planed square edged boards which is fine with me. My question: what is the minimum space to allow between these new boards? Nearly touching boards will do? I want to avoid the gap between boards scenario.
The plan is then to sand down the whole room and apply oil.
PostPosted: Tue Sep 11, 2018 7:28 pm
Has thanked: 416 times
Been thanked: 1566 times
You don't want any space between floorboards, they'll shrink a fair bit anyway once they've been down for a few days.
New timber floorboards should ideally be T&G and well cramped together when laying.
If the size of board available doesn't neatly fit the width you want to fill, you have to cut the last board down until it does.
PostPosted: Tue Sep 11, 2018 7:42 pm
Existing T&G boards are redwood 18mm height, 110mm width (think its called finished width), I can't find the same. I have seen them in white wood which are of poor quality and won't match. Any one know where to buy 18mm t&g redwood floorboards?
PostPosted: Tue Sep 11, 2018 7:50 pm
Has thanked: 710 times
Been thanked: 2043 times
you squash em as tight as you can :lol:
https://duckduckgo.com/?q=floor+board+c ... &ia=images
PostPosted: Tue Sep 11, 2018 7:54 pm
big-all wrote:
:lol:
PostPosted: Tue Sep 11, 2018 8:44 pm
Has thanked: 84 times
Been thanked: 197 times
Try Wickes 124000?
https://www.wickes.co.uk/Wickes-Bordeaux-Pine-Wood-Unlacquered-Flooring---22-x-120-x-2000mm/p/124000
Packs of 4* - 22mm but you are going to sand anyway.
* When I had occasion to use them, not for flooring, I bought numerous packs, sorted out the less-knotted planks, carefully rewrapped the remainder in pallet wrap & took them back for refund. Made a really nice worktop, oiled, still use it daily.
PostPosted: Tue Sep 11, 2018 9:06 pm
arco_iris wrote:
Try Wickes 124000?
I have seen similar, isn't 4mm a lot to sand off? I am using belt sander.
PostPosted: Wed Sep 12, 2018 5:20 pm
Sorted! :huray: My local timber merchant will machine them for me their redwood floorboards from 22mm to 18mm.
There is always a snag though, boards are 113mm mines are 110m width, I think it should be fine. All damaged boards are together so may need to trim last one.
PostPosted: Wed Sep 12, 2018 6:14 pm
is that 110 with a 3mm gap :lol: ???
