It is currently Mon May 27, 2019 2:41 pm
PostPosted: Sun Sep 09, 2018 8:49 pm
Has thanked: 135 times
Hi, How can I repair plasterboard dot and dab external corners prior to painting ?
Sent from my iPhone using TapatalkImage
PostPosted: Mon Sep 10, 2018 6:55 am
Has thanked: 141 times
Been thanked: 183 times
From what I can see in the picture, the corner doesn’t appear to have a corner bead which is used as a straight edge to form a corner.
If that is the case then your options are;
1. Fit a corner bead and either re plaster/use filler to feather out the new high spot ( more durable in the long term as corners get knocked )
2. Fit a external corner moulding to protect the edges then paint the same colour as the wall ( it will do the job but is not ideal if you want to wallpaper at a later date )
3. Fill the damaged area with filler and hope you won’t have to do it every year or two.
https://www.wickes.co.uk/Wickes-Thin-Co ... 9000036437
https://www.wickes.co.uk/Wickes-Pine-Re ... m/p/121163
Mike
