It is currently Fri May 24, 2019 8:26 am
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: Replacing sockets
PostPosted: Wed Sep 05, 2018 4:15 pm
Has thanked: 32 times
Been thanked: 3 times
I'm looking to replace some old plastic face plates, upon removal the old socket has two earth's, two live and two neutrals going to the individual sockets. There is no earth strap going to the metal back box. Can I just replace like for like? The new faceplate has two earth terminals bit assume they are joined so can use just the one? TIA
Sent from my SM-G930F using Tapatalk
 Post subject: Re: Replacing sockets
PostPosted: Wed Sep 05, 2018 4:40 pm
Has thanked: 8 times
Been thanked: 34 times
No, metal fixings should be earthed. You should have a wire (sheathed in yellow/green sleeving) from the earth terminal connecting to the earth terminal in the back box.
PostPosted: Wed Sep 05, 2018 4:53 pm
Even with the plastic face plate? Can I just retro fit this if it's missing?
PostPosted: Wed Sep 05, 2018 5:13 pm
Has thanked: 107 times
Been thanked: 308 times
Faceplate screw heads are usually exposed and fix to the metal back box, any loose wire or due cramming a wire comes into contact with metal box then it has a potential as will the screws, sure there are others reasons too.
PostPosted: Wed Sep 05, 2018 5:18 pm
Oh right ill get some earth cable then to fix to back box!
PostPosted: Wed Sep 05, 2018 6:26 pm
Has thanked: 45 times
Been thanked: 759 times
Easy enough to earth the back box so you should definitely do it.
PostPosted: Wed Sep 05, 2018 6:33 pm
Approved Electrician
Has thanked: 177 times
Been thanked: 598 times
The socket screws USUALLY provide the earth for the back box.
PostPosted: Wed Sep 05, 2018 6:43 pm
So shoukd I run extra earth? Confused!
PostPosted: Wed Sep 05, 2018 7:49 pm
Has thanked: 86 times
Been thanked: 58 times
I always would; it makes sure and is only a tiny bit of extra work. Earth sleeving isn't very costly either.
The contact between screw and conductive eyelet around the face-plate hole may not always be the best, especially as it ages or if it isn't done up properly by someone in future. Another vulnerable time is if things have been purposely loosened (say during decorating). Admittedly, problems are unlikely - but IMO why risk them at all?
Kev
PostPosted: Wed Sep 05, 2018 8:11 pm
Fair comment, where can I buy a tiny length of earth cable and sleeve?
PostPosted: Wed Sep 05, 2018 8:14 pm
Has thanked: 41 times
Been thanked: 1480 times
Any good DIY store.
(If push comes t shove, buy a bit of Twin and earth)
PostPosted: Wed Sep 05, 2018 8:19 pm
someone-else wrote:
Any good DIY store.
PostPosted: Fri Sep 07, 2018 6:44 pm
someone-else wrote:
Any good DIY store.
Probably cheaper to but some flex and strip out the earth.
Although I never fit the flylead unless it's on the spec or required for the regs.
PostPosted: Fri Sep 07, 2018 7:30 pm
Has thanked: 796 times
Been thanked: 896 times
someone-else wrote:
Any good DIY store.
B&Q Washington (Tyne and Wear) did not have earth sleeve. Balls to that ... but easy enough to get 100m from toolstation WTF.
PostPosted: Fri Sep 07, 2018 7:41 pm
OchAye wrote:
someone-else wrote:
Any good DIY store.
I've took advice and replaced the socket with an mk one from screwfix... It's slightly smaller all round that the previous socket and can now seem rough edges... Is this common?
