It is currently Thu Feb 21, 2019 12:02 pm
PostPosted: Wed Sep 05, 2018 3:39 pm
Has thanked: 3 times
Been thanked: 1 times
I need to add a spur and wanted to try and get away with having to pull up laminate and floor boards. However after checking the socket I wanted to spur from it would seem there is already a spur in place. So i went to the only other socket in the room and pulled the face off to find it wasnt a spur...ok so i checked the one in the hall. Again it seemed to be part of the ring. Im lost as to where it could lead to. Is there any thing i can do to find out without ripping up the floor?
PostPosted: Wed Sep 05, 2018 3:52 pm
Has thanked: 702 times
Been thanked: 2027 times
room the other side off the wall??
outside light or power supply ??
do all the wire go in the same direction
PostPosted: Wed Sep 05, 2018 3:59 pm
Has thanked: 40 times
Been thanked: 1429 times
:cb Nope.
(Well you could hire a cable tracer, or you could disconnect everything and check to see what gives continuity) But either way is a either expensive, grief, or both.
PostPosted: Wed Sep 05, 2018 4:44 pm
The room on the otherside is where I want to send the spur to (bathroom conversion).
I'm starting to wonder if it's being used to supply the boiler, even though it's downstairs it is being fed from a fused spur that leads up.
PostPosted: Wed Sep 05, 2018 5:17 pm
turn off the upstairs ring and see what stops working elswhere
otherthings could be bell transformer/ariel booster/attic socket
PostPosted: Wed Sep 05, 2018 8:48 pm
Has thanked: 86 times
Been thanked: 58 times
If that doesn't narrow it down enough, you could then disconnect the actual spur and see what doesn't work after power is restored to the ring. BUT that depends on how competent/confident you are with electrics, as you'll need to electrically identify which is the spur - without endangering yourself.
Also, don't assume that the wiring has been done as you expect, e.g. two wires doesn't 'necessarily' mean a ring. It could be a radial circuit for instance. Or something not to standards - I've seen 2.5mm radials run from a 30A fuse, or 2.5mm spurs run off spurs in a similar manner.
Kev
