It is currently Thu Apr 18, 2019 4:25 pm
PostPosted: Thu Aug 30, 2018 6:44 pm
I have a 40 mm plastic pipe coming in, I somewhow need to clamp it shut to stop the flow of water so I can cut into the pipe further along and replace an existing on/off valve.
P.S. I'm living in Spain, the is 40 mm and is black with thin blue stripes along it. I've tried the clamps I have and they aren't strong enough to squeeze the pipe enough to stop the water flow.
Any help would be greatly appreciated, thank you :)
PostPosted: Thu Aug 30, 2018 7:13 pm
Has thanked: 65 times
Been thanked: 673 times
you should be able to use a proper squeeze off clamp
https://www.toolstation.com/shop/Hand+T ... ool/p39855
There are heavier duty bits of kit
eg. https://www.reedmfgco.com/en/products/p ... off-tools/
your water supplier should be able to isolate the pipe for you
PostPosted: Fri Aug 31, 2018 6:00 am
Has thanked: 78 times
Been thanked: 188 times
There should be a valve next to your water meter, wherever that is. Quite possibly, one either side of the meter, so that the water company can change it.
Are you in an individual property or a block?
PostPosted: Fri Aug 31, 2018 8:27 am
Has thanked: 655 times
Been thanked: 1857 times
At my friends house in Mallorca the water meter is quite some distance from his house and there is a meter cabinet where all the seven properties on his urbanisation have an individual meter and stop cock.
I do not know if this applies where you are?
Painting with BIN
For this message the author dewaltdisney has received gratitude : gas4you
PostPosted: Fri Aug 31, 2018 7:19 pm
Concur, DWD!
PostPosted: Sat Sep 01, 2018 10:39 am
arco_iris wrote:
Concur, DWD!
:lol: :lol: Agreeing with your self, keep taking those pills :thumbright: :thumbright: :scratch:
PostPosted: Sat Sep 01, 2018 1:56 pm
Has thanked: 840 times
Been thanked: 941 times
Failing all of the above, could you freeze the cold main?
Dave
www.drlgas.co.uk
