It is currently Thu Feb 21, 2019 12:03 pm
PostPosted: Sat Aug 11, 2018 4:49 pm
We've recently had a rewire done and the original plan was to run a 9.5kW shower but it's now running off the combi-boiler instead so I have a 10mm2 cable that goes into the consumer below with a 40A MCB.
Now decided to put a couple of double sockets up in the loft so was wondering what's the best and safest to go about it?
Thought about these options...
1. Attach 10mm2 directly into a 13amp double socket - imagine that's quite difficult and would restrict running other double sockets off it?
2. Replace cable with 6mm2 and MCB with 32A, same as the house sockets.
3. Buy an new mini circuit board often seen in garages and attach 10mm2 cable to that then run several sockets off it.
Anyone give any advice on what they would do?
Cheers,
Paul
PostPosted: Sat Aug 11, 2018 5:12 pm
Has thanked: 40 times
Been thanked: 1429 times
It's your choice,
1) That I would like to see.
2) I don't see the point of changing the cable to a smaller one, and then what would you do with the 10mm?
3) Guess
PostPosted: Sat Aug 11, 2018 8:05 pm
Can you suggest a mini circuit board that would do the job mate? E.g a screwfix or toolstation link? Cheers
PostPosted: Sat Aug 11, 2018 8:42 pm
Either place sell them, it's your choice. (I might like "this one" and you may think its cr*p, so that's why its your choice)
PostPosted: Sat Aug 11, 2018 9:11 pm
I'll have a look. Is it a problem that there will effectively be two RCDs protecting this circuit? Is a device attached in the loft causes a fault which consumer unit will trip?
PostPosted: Sun Aug 12, 2018 7:42 am
Approved Electrician
Has thanked: 168 times
Been thanked: 585 times
dualweaponword wrote:
Cheers,
Paul
Terminate the 10mm cable into a 60A Junction box and run 2.5mm cable from there to the sockets. Then swap the MCB for a 32A one if the sockets are a ring or a 20A one if it is a radial.
Small edit. I notice neither Screwfix or Toolstation seem to sell 60A junction boxes. So an alternative to that, if these are the only two shops you going to use is to use a cooker connection point instead of a junction box.
eg https://www.screwfix.com/p/british-gene ... /45080#_=p
