It is currently Sat Apr 20, 2019 7:34 am
 Post subject: question about wall
PostPosted: Sat Aug 11, 2018 3:19 pm
Has thanked: 1 times
Hi there,
New boiler installed and I had to take off the old wired controls as they are of no use anymore.
Could someone please give me some information how is this wall (upper floor) constructed?
Looks like is some kind of lime based plaster (bit fragile) and then what's that black thing? concrete slabs? Its a semi build around 1935 ex LA. Will be ok if I patch using a common patching plaster?
I understand I have to dampen that area at first.
thanx in adavance
Ed
 Post subject: Re: question about wall
PostPosted: Sat Aug 11, 2018 3:43 pm
Has thanked: 65 times
Been thanked: 676 times
looks to be standard blockwork with cement render as the surface in keyed for a plaster skim (is/was it a prefab ?)
Some bonding or cement to fill the hole, and a skim coat over the top - soak the hole with water before filling so what ever you use doesn't have the moisture sucked out of it
im sure a pro will be along shortly.
For this message the author Bob225 has received gratitude : eddybb
PostPosted: Sat Aug 11, 2018 3:53 pm
By the way the external walls are made of brick (cavity wall)
PostPosted: Sun Aug 12, 2018 1:03 am
Has thanked: 786 times
Been thanked: 884 times
Decorator's (powder) filler? Toupret being one example, there are many others too. Just sayin...
