It is currently Tue Apr 23, 2019 1:40 am
PostPosted: Wed Aug 08, 2018 9:53 am
Hi everyone,
I'm replacing LED downlights in the ceiling and the new light has "push fit loop in/out terminals" (http://enlitelighting.com/gb/ProductDetail/EN-DE8). Most of the connections are straight forward, but I'm stuck on the switched light. The existing configuration has 12 wires but the replacement light's push fit connectors have only 6 input terminals, and each terminal fits only one wire.
How should I configure the wires into the terminals?
File comment: Which wires to connect?
File comment: Incumbent connection
PostPosted: Wed Aug 08, 2018 11:21 am
Has thanked: 1550 times
Been thanked: 3892 times
:welcomeuhm:
best bet would be to reconnect everything as it was before, that has your live and neutral loops as well as earth continuity and switched live.
A better photo of the connection markings on the new lamp would help as would any instructions that came with the lamp.
I assume there is more than one light in the room operating from the same switch ?
PostPosted: Wed Aug 08, 2018 12:32 pm
Thanks wine~o. If I try to re-connect the wires as before, there aren't enough terminals in the new light (the terminals don't fit multiple wires in a single terminal). So I'm left with a surplus neutral wire.
Here is a picture of the two lights: old lamp on the right has two wires (N-L) and new lamp on the left has six terminals (E-E-N-L-N-L). The lamp instructions are minimal (it assumes you just plug in the wires).
Yes, this is for a 4 light loop in the kitchen. Thanks!
PostPosted: Wed Aug 08, 2018 2:30 pm
what I meant was re-connect as in your pic "incumbent" reusing the connector blocks, then just take a further cable from the connector blocks to the live (switched) neutral and earth to the new lamp.
I should say I'm not familiar with the fitting you have bought and don't know why it has 2 each of live/neutral/earth terminals, I can only assume that it is a "loop through" arrangement for installing several lamps from one switch.
PostPosted: Wed Aug 08, 2018 3:34 pm
Has thanked: 1235 times
Been thanked: 1110 times
The terminals are loop through terminals as wine~o says.
The switching has to be done as before.
It's clearer when bits of the shots are blown up as in below. It says "loop in and out"
For this message the author Dave54 has received gratitude : wine~o
PostPosted: Wed Aug 08, 2018 3:39 pm
@ dave 54. thanks for that. I zoomed in as much as I could at this end and still couldn't read anything useful
PostPosted: Wed Aug 08, 2018 4:14 pm
No problem mate. :thumbright:
PostPosted: Wed Aug 08, 2018 10:37 pm
Approved Electrician
Has thanked: 175 times
Been thanked: 594 times
I couldn't agree more.
PostPosted: Sun Aug 12, 2018 11:21 pm
Update: I followed your guidance and re-connected the original wiring in the connector box, then cut and fit two wires (live and neutral) to connect the wiring to the light fighting - it all works fine :)
Thanks heaps for your help win~o, Dave 54 and OnlyMe!
PostPosted: Wed Aug 15, 2018 7:40 am
You also need to connect the earth. The earth terminal is there for safety reasons.
