It is currently Sat Apr 20, 2019 11:32 pm
PostPosted: Mon Aug 06, 2018 9:21 am
I'm thinking of hanging small mirror on bathroom tile. Any double sided tape would you reccomend? instead of drilling holes through tiles with fixings.
PostPosted: Mon Aug 06, 2018 9:39 am
Has thanked: 349 times
Been thanked: 1829 times
Gorilla do a double-sided tape that sticks like sh1t to a bedsheet. Don't expect to remove the mirror without breaking it though.
PostPosted: Mon Aug 06, 2018 10:22 am
Has thanked: 709 times
Been thanked: 2041 times
i would mark with a pencil at the bottom on the wall as double sided can let what they are holding"slide" over time
if you get little or no movement your fine
PostPosted: Mon Aug 06, 2018 10:25 am
Has thanked: 45 times
Been thanked: 750 times
3M mounting tape is awesome stuff, they do 2 different versions I think, one is standard strength, the other is crazy strong (and expensive).
Its a double sided tape with strong glue on both sides and a dense foam in between. The most important thing is surface contact though, to equal the holding power of one screw you will need to cover a large proportion of the surface with tape to hold it and prevent creep.
Having said that, if I were adding a mirror to tiles and not wanting to drill holes I would use silicone to stick it in place. As K_e says though, any adhesive mounting will be a one time thing, you will have to break the mirror to remove it, but basic mirrors are cheap so don't worry about that.
PostPosted: Mon Aug 06, 2018 11:56 am
Has thanked: 103 times
Been thanked: 260 times
Standard silicon isn't any good for mirrors as it reacts with the silver coating at least in some cases. Seen it used in dressing rooms at a theatre in oxford and the mirrors started coming off the wall .There is a specific "silicon" , for want of a better word , designed just for mirrors.
PostPosted: Mon Aug 06, 2018 4:41 pm
Yes you are right, I should have mentioned you want a silicone or other adhesive that says it is suitable for Mirrors. I have seen it mentioned on standard tubes though so it doesn't always need to be special stuff.
PostPosted: Mon Aug 06, 2018 5:35 pm
Old School Chippie
Has thanked: 799 times
Been thanked: 1597 times
:withstupid: x2
That's the stuff we've used a few times to fix mirrors in commercial toilets and changing rooms (shops, office blocks, hotels, sports centres, etc). You need to make sure that the gear is well in date (it has a best before date) and the glass needs to be supported in some way while it goes off, too, or it can slide down the wall. Goes off overnight - never lets go.
PostPosted: Tue Aug 07, 2018 4:04 pm
Has thanked: 1550 times
Been thanked: 3892 times
It has a name you know... it's called
m-i-r-r-o-r a-d-h-e-s-i-v-e :wink:
I wonder if command strips might be a better choice given ( I assume) it's a rental ?
https://www.wilko.com/en-uk/command-dam ... /p/0343539
