It is currently Fri Feb 22, 2019 5:10 am
PostPosted: Sun Aug 05, 2018 10:13 pm
Old School Chippie
Has thanked: 785 times
Been thanked: 1560 times
I was looking about the net and came across this on eBay or if you prefer, here on the FFX web site - either way they are the same price.
and I have to say that £100 (almost) for the trimmer motor, fixed base, straight guide (presumably the basic side fence), 2 x (stamped steel) wrenches, 1/4in collet, the small non-standard 10mm (?) guide bushing (I ditched mine almost immediately as the fixed base will take Porter-Cable style screwed-in guide bushes) and the rather less than stellar dust extraction adaptor looks pretty good. Especially as they are also throwing-in a Makpac 4 (Systainer-compatible) carrying case. Don't know if there's any compartmented insert in the case, or whether or not more than one collet is supplied, but at that price it's a bargain if you already own Makita 18 volt lithium tools and have the batteries and charger. BTW these beasties really need a 4Ah battery as a minimum to get the most from them
Whist the fixed base is nothing to write home about, the plunge base is quite nice (especially as it takes 8mm fence rods and the same fine adjuster fence as the Makita RP1110c, deWalt DW613/615/621, Elu MOF96/OF97 and Trend T5, etc) and there's also a tilt base available for those who need it, so it makes this a good addition for somebody who has an RT0700, has the Mak batteries but needs to go cordless with a trimmer/small router.
For this message the author Job and Knock has received thanks - 2: big-all, Dave54
PostPosted: Wed Aug 08, 2018 5:19 pm
Old School Chippie
A small update on what's actually in the box.... Having just opened one the FFX deal includes the following:-
Makita DRT50JZ 18 volt cordless trim router (laminate trimmer) motor unit
Fixed (trimmer) base
Straight guide (basic steel side fence)
1/4in collet
3/8in collet
Small steel guide bushing, 10mm OD
Dust extraction adaptor
Makita Makpac 4 (Systainer-compatible) carrying case
Soft compartmented divider insert
Pity there's no 8mm collet, but hey-ho, you can't have everything
There are loads of options available for these tools and quite frankly a Makpac 4 alone (no inserts) will normally cost you £50 at Screwfix or £29 at Power Tool World, whilst the soft insrt is generally about £10 - which means that the router itself costs just £60. Well done FFX, I say
PostPosted: Sat Aug 11, 2018 4:57 am
Has thanked: 19 times
Been thanked: 46 times
Does it take the normal black Makita guide bushes in the plunge base?
PostPosted: Sat Aug 11, 2018 7:21 am
£133 on ebay - £129 on FFX. Missed the boat by the looks of things.
PostPosted: Sat Aug 11, 2018 10:13 am
Old School Chippie
Do you mean the ones from the RP2300 and RP1801 routers? No. The fixed base uses either a steel Makita guide bush (only know of the 10mm in this range) or a 2-party Porter-Cable style guide bush such as these (metric) and these (Imperial)
In the Silverline set that big ring thing with 4 holes in it at the left rear of the guide bush set is an adaptor for the large 1/2in Makita routers which carries the P-C style guide bushes. It also works with the RT0700/Katsu plunge bases as well (they are designed to use the same Makit guide bushes as tthe big routers)
PostPosted: Sat Aug 11, 2018 3:42 pm
Thanks, I have the Katsu with plunge base and also have the Silverline set as Amazon reviews said that was the only bushes that fitted, sure, they do fit the plunge base but so do the Makita regular bushes as you mention - there appears to be no type of bush that fits the standard (round) fixed base. Not really a problem for me tbh as I mostly only use it with the plunge base on my hinge jig and for rounding over.
Still think I will buy the DRT50JZ as I want to go as cordless as possible from now on and use it with the Katsu plunge base - just replaced my SP6000J with the 36v cordless version (DSP600ZJ) and that is fantastic.
Have you had a chance to have a go with the cordless mitre saw from Makita, the smaller one with 190mm blade?
PostPosted: Sat Aug 11, 2018 11:51 pm
Old School Chippie
The Porter-Cable type 2-part threaded guide bush does fit the fixed base on the RT0700 and the Katsu. Those P-C guide bushes are available in Imperial from Silverline (see previous post) and in metric from Trend (16, 16.7 and 30mm [scroll down to "US Style Guide Bushes"] - the most suitable sizes for use with router jigs) and Axminster Power Tool (10, 12, 14, 16, 18, 20, 24 and 32mm as a set). Not really a problem for me tbh as I mostly only use it with the plunge base on my hinge jig and for rounding over. The 16mm one can be used with the Trend hinge jig and a 12mm diameter cutter, the Trend 16.7mm allows the use of a 12.7mm (1/2in) hinge recessing cutter with the Trend hinge jig and the 24mm one (in the Ax set) allows the use of a 20mm cutter in the Trend hinge jig for dealing with radius corner hinges because the standard radius on those is 10mm.
I went onto the DSP600 a few months back and have all but stopped using my Festool TS55. For site work the 2 x 18 volt set-up is more than adequate and has more than enough power (as well as never needing to go into safety mode because some moron has just plugged a 2kW angle grinder into my transformetr!) although if I were cutting all day it would still be a coin toss as to which is the better tool for the job. The one thing I didn't like about the DSP is that ultra thin blue blade that Makita supply - mine distorted the first time it hit a hard knot, so I switched to DW Flexvolt blades (42t) which sadly didn't impress me (on the other hand the DW Xtreme thin kerf saw blades were/are brilliant on my Makita DHS680 cordless rip saw), so I'm now trying acouple of Freud thin kerf blades which seem a lot better. Next thing will be a cordless/110 volt vacuum - class L (as class M is not yet made), I hope.
No. I did try a colleagues DW 216mm last year and came away impressed at how much power there is, though, and I have used the corded 190mm which is remarkably small and light
PostPosted: Sun Aug 12, 2018 5:23 am
I must be doing something wrong then as I can't get it to work - the bush and threaded ring just pass straight through the aperture in the base plate with nothing to fix to, the adapter plate is of course too big to work with it too.
PostPosted: Sun Aug 12, 2018 12:14 pm
Old School Chippie
Installing a Porter-Cable guide bush in the Makita RT0700/Katsu fixed base:
Makita RT0700 and DRT50 Fixed Base with PC Guide Bush 001_01.JPG [ 21.55 KiB | Viewed 921 times ]
Above: The Makita RT0700 fixed base with the Porter-Cable guide bush beneath it including the locking ring
Below: The P-C guide bush (less the locking ring) is dropped into the fixed base from beneath
Makita RT0700 and DRT50 Fixed Base with PC Guide Bush 001_02.JPG [ 35.84 KiB | Viewed 921 times ]
Makita RT0700 and DRT50 Fixed Base with PC Guide Bush 001_03.JPG [ 48.47 KiB | Viewed 921 times ]
Above: The ring is then screwed onto the threaded portion of the guide bush from inside the base
Below: ...et voila
Makita RT0700 and DRT50 Fixed Base with PC Guide Bush 001_04.JPG [ 52.68 KiB | Viewed 921 times ]
Tried this with both my Makita fixed bases this morning as well as the Katsu fixed base. Same results. Note that it is only really possible to perform this installation with the motor removed from the base
Above: The Katsu motor installed in the Makita RT0700 plunge base
Below: The P-C guide bush adaptor (in this case a Makita OEM item, the Silverline is identical other than being made from brass rather than aluminium) is dropped into the plunge base from beneath and locked in place using the two JIS#2 (like Phillips #2) screws supplied with the base
Above: The guide bush is inserted from beneath the adaptor as before, and then the locking ring is screwed onto the threaded portion of the guide bush from inside the base
Below: ...and there you have it
I have also done this in the past with the Katsu plunge base with the self-same results as on the Makita plunge base
Sorry for the manky photos, but these were taken on the phone for speed rather than quality. Hope that clarifies things
For this message the author Job and Knock has received gratitude : Bill Darr
PostPosted: Sun Aug 12, 2018 5:34 pm
Thanks for taking the time and trouble to do the pictures etc. When you offer up the bush to the underside of the base does it come up against a flange to hold it in place so you can then screw on the locking ring from above?
Sadly my fixed base must be different to yours as there is no flange on mine for the bush to hold against while the lock ring is screwed on, it simply passes straight through the base aperture.
PostPosted: Mon Aug 13, 2018 10:14 pm
Old School Chippie
The "lip" is in the black plastic sub base, Bill. What size is yours? Any chance of a photo? Are we tslking about the Katsu here?
PostPosted: Tue Aug 14, 2018 4:27 am
Yes it's the Katsu. I have just ordered the DRT50 so when it arrives I will take a picture of the two side by side.
PostPosted: Sat Aug 18, 2018 3:44 pm
For anybody's future reference here are the two bases, the Katsu is different to the Makita as it has no flange inside the base to hold the guide bush. The Katsu is the lower base, the silver part is just from the router body.
