It is currently Sat May 25, 2019 8:11 am
 Post subject: Some input needed plz
PostPosted: Thu Aug 02, 2018 9:47 pm
Has thanked: 1 times
Hi guys.
So, what you see in the attached pic, is a profile bender. Yes, it is self made. Works 100%. Arches up to 38mm square tubing of 1.6 thick. Very durable and sturdy.
My next step, is to ad a motor, with reverse action.
Now, i have a motor 230v AC, with reverse, that i harvested from a treadmill. It set the incline of the track up or down.
It has a slow speed. Slow enough for what i need to do with it. My question is, "WHAT AND HOW DO I CONNECT TO THE MOTOR TO CONTROL THE DIRECTION OF MOTION, THAT I CAN FIND IN ANY STORE?
Sure, there are many good options, but pricey. Im looking for ideas to make my own control panel. What are the key items i may need?
Please, no toddler aged remarksImageImage
Sent from my vivo Y27 using Tapatalk
PostPosted: Thu Aug 02, 2018 11:07 pm
Has thanked: 349 times
Been thanked: 1829 times
What connections does the motor have? Two wire or more?
PostPosted: Fri Aug 03, 2018 1:33 am
3, im sure. Needs the 12mfu cap though. It can go both ways, but without a controller, its useless
PostPosted: Fri Aug 03, 2018 9:04 am
A simple motor reversing switch is all that's required then.
https://www.ebay.co.uk/itm/220V-380V-Au ... Swi8VZWzZZ
you can also purchase this type of thing ready-mounted in a box with the appropriate glands and knob (see RS Components and/or Farnell etc for examples) or chose your own version of box/mounting etc.
PostPosted: Fri Aug 03, 2018 11:54 pm
Thanks. Will keep an eye out
PostPosted: Sat Aug 04, 2018 12:00 am
Has thanked: 710 times
Been thanked: 2043 times
a motors is no good without a transmission to convert the say 2000rpm to usable power
in other words hydralic or gearing to convert speed to power
PostPosted: Sat Aug 04, 2018 2:35 pm
I was thinking of using a bigger pulley/sprocket than what is on the motor, to slow the ratio down
PostPosted: Sat Aug 04, 2018 2:36 pm
It does not need much power conversion. That force gets controlled by the press im using.
PostPosted: Sat Aug 04, 2018 3:18 pm
i suspect you will need a reduction off many tens perhaps 50-1 ratio
or is this just to move it along the rack rather than replace the jack :dunno:
PostPosted: Sat Aug 04, 2018 3:38 pm
Has thanked: 1245 times
Been thanked: 1121 times
The only thing is that you say this is a motor for adjusting the incline? What's the power rating?
I'd have thought that such a motor was probably only fractional HP.
Looking online, it appears that similarly sized commercial roller benders use a 1.5 HP motor as the drive motor.
Obviously that would be considerably geared down. Apart from increasing the torque it has to be fairly slow to be controllable.
PostPosted: Tue Aug 07, 2018 7:14 pm
Old School Chippie
Has thanked: 808 times
Been thanked: 1616 times
The other thing about commercial motors used in low speed applications is that they often have 4-poles, giving an output shaft speed of 1500rpm. These slow speed motors generate more torque than equivalent 2-pole motors and because they are designed to operate at such low speeds they generally are much longer lived than the 2-pole equivalent motors
For this message the author Job and Knock has received gratitude : Dave54
PostPosted: Tue Aug 07, 2018 7:28 pm
You're right of course J & K, and that's the type of motor I'd choose, assuming there's no 3ph available. Even so I wonder if you'd run into problems with the number of reversing start / stops needed. You'd probably need DC injection braking as well. You'd want to avoid "plugging" or braking by reverse running.
I don't know much about treadmills, but I'd assume that the incline adjustment motor is probably a very small DC motor. Looking online it looks as if they are.
Users browsing this forum: OnlyMe and 2 guests
