It is currently Sat May 25, 2019 8:11 am
PostPosted: Sun Jul 29, 2018 8:27 pm
Please can someone advise on a suitable light dimmer switch for the following light fitting please? Preferably a chrome one as opposed to white. Thank-you.
Range Caelus
Style Contemporary
Finish Chrome effect
Material Metal
Height (mm) 450mm
Diameter (mm) 760mm
Dimmable Non dimmable
Number of lamps 14
Bulb Type Required G9
Bulb supplied Bulb sold separately
Maximum bulb wattage 40W
IP rating IP20
I know it says non-dimmable but i've seen this in a hotel and it was being dimmed.
PostPosted: Sun Jul 29, 2018 10:11 pm
Approved Electrician
Has thanked: 177 times
Been thanked: 598 times
:welcomeuhm:
Of course it is dimmable. It uses G9 230V lamps.
Your dimmer depends on the lamps you fit. Do you want LED lamps or halogen lamps - ISTR the incandescent 40W lamps have been phased out.
PostPosted: Mon Jul 30, 2018 5:41 am
It says it doesnt come with bulbs but it did. If I get the details off the bulbs would that help to recommend which dimmer? Thank-you for your help.
PostPosted: Mon Jul 30, 2018 9:01 am
OK the bulbs that came with G9 240v-50hz 40W bulbs x 14. Please can you suggest what spec dimmer would work please? Thank-you
PostPosted: Mon Jul 30, 2018 9:33 am
Just a thought, ive seen G9 led dimmable bulbs on amazon so if I swap put the bulbs that came with the light for these will my problem be solved? Is it just the bulbs that determine if its dimmable?
PostPosted: Mon Jul 30, 2018 4:49 pm
Has thanked: 1561 times
Been thanked: 3914 times
:welcomeuhm:
14 x 40 Watt is 560 watts, a quick google brings up this https://www.myswitchshop.com/index.php? ... 98h3srqlo6
which will probably be suitable .
The LEDs you have found will be much lower wattage and would require a completely different dimmer.
Also note that if the bulbs you already have are halogen (I suspect they are) that dimming them will considerably shorten their lifespan.
PostPosted: Mon Jul 30, 2018 6:57 pm
wine~o , you have written what I was going to write.
I was also going to suggest a varilight dimmer (not necessarily a ultra flat plate chrome one).
The lamps that came with the light are dimmable. But at 40W will require a 1000W dimmer.
For this message the author OnlyMe has received gratitude : wine~o
PostPosted: Mon Jul 30, 2018 7:31 pm
Has thanked: 86 times
Been thanked: 58 times
Yes, as above.
It is the type of bulb that determines the type of dimmer you need (or even if a dimmer can be used). The supplied bulbs sound like they are of a traditional filament design (albeit probably halogen), and can be dimmed by a traditional type of dimmer. Provided the dimmer is suitably rated for the total wattage involved, as also mentioned.
With your light fitting the bulbs are replaceable, and you may perhaps want to replace them with a lower energy LED bulb. But in that case, an LED compatible dimmer should be used instead, so it is worth thinking about before the dimmer is bought.
Be aware though that with low energy can come greater complication. A lot of LED G9s are bigger than the standard (halogen) format, and not all light fittings have clearance for them so they aren't always an option. Plus, not all dimmable LED bulbs dim as successfully as halogen bulbs either; they tend not to dim to such low levels and some can be fussy about the exact dimmer used.
Kev
PostPosted: Tue Jul 31, 2018 12:28 pm
Brilliant thank you for. Your. Replies. You've been very helpful!
