It is currently Fri Feb 22, 2019 12:10 am
 Post subject: Wiring issue
PostPosted: Sat Jul 28, 2018 7:57 pm
I have a wiring issue. Problem 2 gang 2way switch in hall controls hall light (hall works fine) and landing light. The issue is I can turn the landing light on and off from the hall no problem, when landing light is turned on from the hall I can go upstairs and turn the landing light on and off ok from upstairs. However if I turn the landing light off from the hall the landing light cannot be turned on from upstairs. I have shown a pic of the hall 2gang switch and how it is currently wired.
Help please!
 Post subject: Re: Wiring issue
PostPosted: Sat Jul 28, 2018 8:57 pm
Has thanked: 40 times
Been thanked: 1429 times
How long has it been like this?
Have you touched it?
Has some one else touched it?
What does the other switch and terminals look like?
PostPosted: Sat Jul 28, 2018 9:00 pm
Always since I moved in 2 years ago but now getting on my nerves.
No one touched the landing switch is 1 gang 3 terminal
PostPosted: Mon Jul 30, 2018 5:07 pm
Has thanked: 1531 times
Been thanked: 3852 times
:welcomeuhm:
Without significant rewiring you are stuck with what you have.
The switch in the pic has only one live feed, this is actually a "switched live" from the upstairs switch, you then have a "bridging live" from one side of the switch to the other, effectively only when the upstairs and downstairs switches are in the correct positions does this "bridging live" actually become live.
I hope that makes (some) sense.
PostPosted: Mon Jul 30, 2018 7:14 pm
Approved Electrician
Has thanked: 168 times
Been thanked: 585 times
Sorry to disagree.
The picture is not clear enough to show what is going on, however it is not unusual to have a bridge in a lighting circuit.
A clearer picture is needed.
PostPosted: Mon Jul 30, 2018 7:28 pm
Has thanked: 70 times
Been thanked: 144 times
OnlyMe wrote:
Sorry to disagree.
Whilst we trust OnlyMe as the resident expert, may I point out that in addition to the bridge there are three red wires and only one black. T&E cable of that age is one of each, that's why we need the bigger picture.
I recently came across, in one of my properties, a two-way circuit (which should have, at that pre-harmonised time, used red/blue/yellow 3+E) that had been set up with two lengths of r/b t&e with one core of one twin unused.
(In addition it was joined/connected at the rose! My solution, rip out & start again.)
PostPosted: Mon Jul 30, 2018 7:40 pm
Sorry to disagree.
Feel free to disagree. I often disagree with myself. :help:
PostPosted: Mon Jul 30, 2018 7:46 pm
arco_iris wrote:
OnlyMe wrote:
Sorry to disagree.
Ever heard of singles cables?
PostPosted: Mon Jul 30, 2018 8:43 pm
Not by that term, do you mean t&e with outer cores the same (never seen or come across red/red, know you can get brown/brown but not seen an electrician use it). Or single core cable to be used inside conduit/trunking (as I often have, myself)?
Unlikely to be found in OP's residential property? :dunno:
PostPosted: Mon Jul 30, 2018 8:53 pm
Single core double sheathed cable, either with or without cpc.
Very commonly used in lighting circuit in the past.
PostPosted: Mon Jul 30, 2018 9:05 pm
Did it have grey outer, like the pic.?
Does the pictured grey outer have two cores?
Per previous, needs more pictures, doesn't it.
