It is currently Thu Apr 18, 2019 11:36 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
 Post subject: Exterior work
PostPosted: Fri Jul 13, 2018 10:30 am
Has thanked: 246 times
Been thanked: 251 times
I think I'm officially done with outsides now especially wood. Too hot, too cold, too humid, too much moisture.
Just been back to a job where I did a load of windows, thought I'd prepped very well but half the bottom beads were cracked, split and bubbled. This was a Zinsser system.
Conclusion is cheap/crappy wood with tonnes of movement, thought the Allcoat would have held better.
Customer isn't bothered and we agreed to just maintain it each year and not hope for too much.
But it does fill me with dread when I get asked to do more wood especially if your relying on scaffolding. Last thing I want is system failing and forking out for scaffolding to put it right.
So therefore as the Dragons say "I'm out"
Feel better for it too.
Rant over...... ps big up to the guys/girls who continually make it work. :thumbright:
For this message the author Desmondo15 has received gratitude : ian gibson
 Post subject: Re: Exterior work
PostPosted: Fri Jul 13, 2018 5:11 pm
Has thanked: 100 times
Been thanked: 122 times
I'm thinking the same way. Fed up of going to see jobs where the exterior has been neglected for so long and you are expected to work miracles. Just finished a huge exterior where the timber Georgian windows had not been painted for over twenty years. Had to chop out all the rot, apply wood hardener, preservative and tons of two part filler, power sand, fill, power sand some more, endless prep. Soul destroying.
PostPosted: Fri Jul 13, 2018 5:56 pm
Has thanked: 1234 times
Been thanked: 1110 times
I think that what happens is that you wake up one morning and realise that life really is too short for whatever.
Having a good, strong "No" is an essential part of every craftsman's toolkit.
I'm not a painter and decorator, but I used to do my own exterior woodwork.
As you say, endless prep, to see it back to square one after a fairly short time.
Fitted placcy windows to our place, and never looked back.
For this message the author Dave54 has received gratitude : ian gibson
PostPosted: Fri Jul 13, 2018 6:03 pm
And after all that effort the paint could still fail......
PostPosted: Fri Jul 13, 2018 6:05 pm
It's exactly how I feel. I'm going to find something else to fill that void that I might actually enjoy...is it possible????
PostPosted: Fri Jul 13, 2018 6:31 pm
A pint of real ale outside a local hostelry, and sit and watch other people painting woodwork would be my choice! :mrgreen:
PostPosted: Fri Jul 13, 2018 6:53 pm
Ahh perfect!!!
PostPosted: Fri Jul 13, 2018 8:59 pm
Has thanked: 786 times
Been thanked: 884 times
Yes. And even worse when the wood has aged, whatever you do does not want to last. However, as an amateur, I am not sure I would go for zinsser for this that 'n the other. The zinsser chemists worked out a good formula for two primers (BIN with shellac and waterbased with whatever, OK and an oil based primer). At some point marketing and the accountants in the company take over, and they will produce more and more stuff based on the two or three basic products they have. I would be inclined to use the products of a company that has always done what the product is meant to do, and yup, I will miss the latest innovation but there again it is not my livelihood. Experimenting may mean I have to do it again or if it was my job the client has to pay again or my reputation suffers.
Just sticking my (wh)oar in :lol: :lol:
For this message the author OchAye has received gratitude : Desmondo15
PostPosted: Fri Jul 13, 2018 9:06 pm
Coverstain is their best exterior primer and Allcoat is highly recommended, the 2 work together also. But still it wasn't enough in some areas, a small %.
For this message the author Desmondo15 has received gratitude : OchAye
PostPosted: Fri Jul 13, 2018 9:10 pm
Do you mean when the wood is past its best or "in some areas" as in too much exposure to sun or rain etc. The problem is you need 5+ years (yes, more/less?) to know if an exterior system works.
PostPosted: Fri Jul 13, 2018 9:35 pm
If the wood is pretty sound then most exterior paints will suffice. Important to remember that bog standard oil undercoat is no good for exteriors as it is not flexible enough. The problems really start when you have neglected rotting timber and if you don't do it properly it won't last long. Remove the rot, coat it with wood hardener, coat it with preservative, use two part filler (car body stuff works really well) and use one of the many flexible primer/undercoats and glosses. Zinsser allcoat is brilliant stuff but I've yet to use it on poorly maintained timber. I've heard other painters say they've had problems with coverstain failing on exteriors.
For this message the author ian gibson has received gratitude : Desmondo15
PostPosted: Sat Jul 14, 2018 8:11 am
Has thanked: 4 times
Been thanked: 155 times
i'm the same.I've got to do a converted chapel in a few weeks & then possibly one more then that's it. I don't mind doing the work.It's working off ladders & the older i get the more i see how dangerous it is. The price of scaffolding is so expensive as well.A lot of the time it's more expensive than the actual painting job.
For this message the author dubman2 has received gratitude : Desmondo15
PostPosted: Sun Jul 15, 2018 7:24 am
Been thanked: 15 times
I start my last out door job tomorrow 2/3 days work and thats it no more. I will probably still do the odd front door or garage doors for existing customers if needed and thats it. :thumbup:
For this message the author bitzz has received gratitude : Desmondo15
PostPosted: Sun Jul 15, 2018 4:16 pm
Scaffolding is becoming too expensive on a lot of jobs, everyone deserves to be safe. I can never see how windows can be done to the same standard off a ladder, maybe I'm wrong but it's a long time to stand on a rung - my feet go numb - too many pies.
PostPosted: Sun Jul 15, 2018 4:17 pm
Amen to that :thumbright:
