It is currently Mon May 20, 2019 2:10 pm
 Post subject: Leaking Toilet
PostPosted: Mon Jul 09, 2018 12:51 pm
Has thanked: 10 times
Been thanked: 4 times
I noticed yesterday that my downstairs toilet has water running into the pan? its only a small amount, now when I took the lid off the cistern there isn't any water running into the overflow, any ideas? :dunno:
 Post subject: Re: Leaking Toilet
PostPosted: Mon Jul 09, 2018 12:56 pm
Has thanked: 659 times
Been thanked: 1875 times
It is letting by the flush valve. A photo would help us advise on how to deal with it as there are many flush mechanisms.
Painting with BIN
PostPosted: Mon Jul 09, 2018 5:49 pm
Has thanked: 65 times
Been thanked: 686 times
its a bit of lime or grit stuck in the flush valve, depending on the make you can twist the head and remove it to clean it, Tbh a few good flushes cures it most times
PostPosted: Mon Jul 09, 2018 6:13 pm
Has thanked: 86 times
Been thanked: 58 times
Yes, i agree with the above.
Though just to mention another less likely possibility - in some cases there can be two overflows; the old/traditional one (e.g. to outside) may be left there when a newer down-the-pan type is put in. So in that case, water not going down the old overflow doesn't necessarily mean its not going down the new one into the pan.
Kev
PostPosted: Tue Jul 10, 2018 6:22 am
This is a picture of the cistern
File comment: Picture of inside cistern
PostPosted: Tue Jul 10, 2018 8:24 am
Looking at that I now think that the inlet valve is letting by. Often the washer has to be cleaned or replaced. The big blue nut with hand grip ridges (top of the picture) has to be undone (water off) to take this out for service or replacement. This video will give you the idea https://www.youtube.com/watch?v=r2ot2cypULs
Painting with BIN
PostPosted: Tue Jul 10, 2018 8:33 am
Has thanked: 1560 times
Been thanked: 3911 times
Before doing as DWD suggests I would remove that blue nut that has fallen to the bottom of the cistern from somewhere.
It is probably stopping the valve closing properly'
For this message the author wine~o has received gratitude : bgatty68
PostPosted: Thu Jul 12, 2018 10:26 am
thanks DWD and Wine~o how embarrassing that you saw that from the picture and i didn't spot that when i took the picture. :oops: :oops: :shock: :shock:
PostPosted: Thu Jul 12, 2018 4:23 pm
looks like a Torbeck fill valve and a Fluidmaster flush valve - turn the water off to the cistern and flush it you should be able to get your fingers in the gap at the bottom - get someone to push/hold the button and you should be able to feel/clean the seal
PostPosted: Thu Jul 12, 2018 5:06 pm
So far as I can tell B Gatty has sorted the issue by removing the nut that was stopping the flush mech closing :wink:
Users browsing this forum: Majestic-12 [Bot] and 0 guests
